Themen: 45
There is no login necessary, but anyway, here is the file:
[edit] gelöscht [/edit]
Regarding the IRS2092 - I think you will not find a model...
Themen: 45
1. unpack the .zip file,
2. throw away everything except ir2011.sub
3. open LTspice and draw a symbol with 8 pins, save it as ir2011.asy, same directory as ir2011.sub,
4. create a new schematic in LTspice, save it in the same directory, use the created symbol and include the ir2011.sub.
It works, maybe... ;-). I forgot some details, you will see
(Forum-script or Miss Servi messed up the link to ir2011.zip...)
kahlo thank you,
I've tried it, but it will take some time to build the complete schematic around the IR2011.
Maybe another a simple question.
Is it possible to get a sawtooth/triangle waveform in LTspice (like a voltage source) or even en PWM signal?
Themen: 45
look
here for posting #187
Themen: 45
if you share all necessary simulation files... I'm sure somebody here will find something
Allright, I've output from the LT1016, but no output from the IR2011.
Which file are the necessary simulation files?
Themen: 45
?.asc
IR2011.asy
Where is the load in your schematic?
Themen: 45
that took some time...
classd_edit.asc
IR2011.asy
Please change "Simulate > Control Panel > Spice > Engine/Solver" to "Alternate".
Summary of problems solved: Bad pin numbering in symbol, tiny note in model "The "Low side return (COM)" pin must be grounded.".
;deal2
Themen: 45
Hey, ich hab das letzte Wort, ist auch selten
hm, erinnert mich an das ehepaar :
er sagt: du musst auch immer das letzte wort haben!
sagt sie: ich wusste ja nicht, dass du nichts mehr sagen willst...
Themen: 45
Wenn ich das noch ein paar mal mache, wird irgendwann auffallen, dass immer dieselben Fehler gemacht werden...
Jetzo hebbich doch noch was gesagt, Herzallerliebste
