THD, efficiency, freq. range, etc.
Alright, I spent the better part of today getting re-acquainted with LTspice and I entered the full schematic, created simbols for the parts that weren't in the library (such as the IR2011 driver) and I was able to get it to work.
However, since I've never used LTspice to simulate amplifier efficiency, THD and other things you'd like to know prior to putting the idea to reality I'd like to know how to do this. The following things are of interest to me:
- Frequency range, how linear is the amp?
- Efficiency, power in vs. power out ratio
- THD, how about the distortion?
- Carrier frequency, how to find the carrier frequency?
- etc.
These questions may seem trivial to those of you that have used LTspice for a while but remember I'm new to LTspice, I did work with Spice in school, but that's a different beast and a lot of years ago as well.
Any suggestions are most welcome!
Best regards,
Sander Sassen
Also einmal das volle Programm Rolleyes
Diese Linearitätskurve hab ich hier schon öfter gesehen. Aber ich selbst hab die noch nie angefertigt. Weiß jemand Antwort auf Sanders 1.Frage?
Okay, noch mal ein par fragen, erstmal die THD messung, jetzt mach ich daB mit die nachtsen commands, hab ich daB richtig gemacht?
Input: SINE(0 1 10k)
.tran 0 500u 1u uic
.four 10kHz 10 V(OUTPUT)
Select FFT > 16384 samples > Hann window
Und dan guck ich mal die .log file an in der \LTC\SwCADIII dir.
GruB,
Sander.
Absolut korrekt. In der error-log-File erscheint die Oberwellenanalyse, eben der THD. Die FFT ist eigentlich nur Show. Bringt gleiche Ergebnisse.
Ganz anders sieht das aber aus, wenn man Intermodulationen feststellen will.
Bei der "four-Anweisung" muß man eben vorher wissen, was man sucht.
Im Gegensatz dazu zeigt die FFT, was wirklich da ist.
Die FFT zeigt Dir auch den Carrier!
And where is FFT ? I can't find it.
Zitat:And where is FFT ?
it is FFT function in SW-cad -- or what are you looking for?
