CSRA64215 config / power / charging
There is just one place where external charger is suggested ("charger configuration") and there is no option for internal. Not sure what should be set there and the datasheet does not seem to be conclusive here.
There's also a ticked box for "Disable leds" there...maybe that has something to do with it. Will check again a day after tomorrow.
All in all the most critical question for me is the power on/off. I'd like to have a single button to be used as On/off, pairing and play/pause (long, very long, short respectively). That should typically work by MFB (Logical ID #1 / PIO 18) but seems to do only pairing and pausing part.
If possible, please take a look at the txt file I attached in the original post. It's basically a PSR file just with changed extension.
Thanks for all the feedback so far!
Best regards
WL
CSRA64215 config / power / charging - von WLA - 15.06.2020, 05:32 PM
RE: CSRA64215 config / power / charging - von WLA - 15.06.2020, 08:57 PM
RE: CSRA64215 config / power / charging - von WLA - 15.06.2020, 10:48 PM
RE: CSRA64215 config / power / charging - von WLA - 21.06.2020, 06:51 PM
RE: CSRA64215 config / power / charging - von WLA - 23.06.2020, 10:43 AM
