PCM5242 + TPA3251 == TAS3251
#10
Hi...Raspberry Pi has two i2s inputs (header, HDMI). You could potentially delay the data with a simple FIFO written in a tight real-time loop in software after reading in the data from an i2s input board.
The TAS3251 is an interesting chip but the bring-up on it is heavy. It's a very complicated device and requires a lot of heavy lifting to get something basic working. Unless you're planning on making a ton of these devices, you're better off with the pricey evaluation board just for basic DSP/DAC hacking.
PCM5242 + TPA3251 == TAS3251 - von christianw. - 26.06.2018, 03:56 PM
RE: PCM5242 + TPA3251 == TAS3251 - von christianw. - 26.06.2018, 05:54 PM
RE: PCM5242 + TPA3251 == TAS3251 - von alfsch - 27.06.2018, 05:13 PM
RE: PCM5242 + TPA3251 == TAS3251 - von MP1993 - 27.06.2018, 05:47 PM
RE: PCM5242 + TPA3251 == TAS3251 - von Bandre - 27.06.2018, 07:46 PM
RE: PCM5242 + TPA3251 == TAS3251 - von MP1993 - 27.06.2018, 09:15 PM
RE: PCM5242 + TPA3251 == TAS3251 - von christianw. - 27.06.2018, 06:08 PM
RE: PCM5242 + TPA3251 == TAS3251 - von alfsch - 27.06.2018, 06:34 PM
RE: PCM5242 + TPA3251 == TAS3251 - von christianw. - 27.06.2018, 10:25 PM
RE: PCM5242 + TPA3251 == TAS3251 - von GussKolb - 25.03.2020, 07:02 PM
