ETF 2009
So Kinners... ich mach da kein großes Geheimnis draus:
JEDER (also auch Frank) kann seine Modelle mit einem Handstreich verschlüsseln.
http://ltspice.linear.com/software/scad3.pdf
LTspice can generate and read a special form of encrypted
libraries. This allows one user to prepare a library that
another user can use in a simulation without revealing the
implementation of the library. A reasonable attempt has
been made to make the encrypted library difficult to decode
by unauthorized concerns, but it cannot be considered
perfectly secure if for no other reason than it is
implemented in software.
To prepare an encrypted library, you need to invoke LTspice
from the command line with the command line option "-
encrypt". You will need to first backup the library
because it will be replaced with the encrypted version.
THERE EXISTS NO UTILITY TO CONVERT AN ENCRYPTED LIBRARY
BACK TO CLEAR TEXT. Below summarizes the two steps:
1. Make a backup copy of the library. The
version you encrypt is deleted.
2. From a command line, type
scad3.exe -encrypt <filename>
The file <filename> will be replaced with an encrypted
version. The encryption process will take a few minutes.
One this process is finished, you have an encrypted ASCII
file. It's possible to add a copyright notice above the "*
Begin:" line, but the first 9 lines of the file must remain
unchanged and each line of copyright notice you add must
begin with the character '*'.
That is, here an encrypted file written by LTspice:
* LTspice Encrypted File
* This encrypted file has been supplied by a 3rd
* party vendor that does not wish to publicize
75
* the technology used to implement this library.
* Permission is granted to use this file for
* simulations but not to reverse engineer its
* contents.
* Begin:
50 3E 46 0F FA 6E 67 FF B8 4D D9 62 14
Und das hat Frank - trotz mehrjähriger Modell-Erstellung mit Spice - nicht gewusst? misstrau
Ne Kinners. Frank verweigert uns die Kennlinienschar-Überprüfung nur aus einem einzigen Grund: seine Modelle taugen nichts. Und dass er das mit dem "encrypt"-Flag nicht gewusst hat ist im besten Fall peinlich.
Anyway...
von uns gibts nun x-beliebige Modelle in höchster Qualität. Man braucht sie sich nur zu wünschen und ein Datenblatt muss natürlich in ausreichender Qualität zur Verfügung stehen.
ETF 2009 - von audiosix - 24.11.2009, 04:07 PM
RE: ETF 2009 - von Gerd - 24.11.2009, 04:30 PM
[Kein Betreff] - von audiosix - 24.11.2009, 04:57 PM
[Kein Betreff] - von obamaimladen - 24.11.2009, 06:40 PM
Wurde schon vorgestellt ... - von obamaimladen - 24.11.2009, 06:55 PM
RE: ETF 2009 - von rumlungerer - 24.11.2009, 06:58 PM
[Kein Betreff] - von Rumgucker - 24.11.2009, 06:59 PM
RE: Wurde schon vorgestellt ... - von audiosix - 24.11.2009, 08:33 PM
[Kein Betreff] - von rumlungerer - 24.11.2009, 11:24 PM
RE: RE: Wurde schon vorgestellt ... - von obamaimladen - 25.11.2009, 09:24 AM
[Kein Betreff] - von audiosix - 25.11.2009, 10:13 AM
[Kein Betreff] - von obamaimladen - 25.11.2009, 10:20 AM
[Kein Betreff] - von audiosix - 25.11.2009, 10:46 AM
[Kein Betreff] - von obamaimladen - 25.11.2009, 10:52 AM
RE: - von Rumgucker - 25.11.2009, 10:54 AM
[Kein Betreff] - von kahlo - 25.11.2009, 11:00 AM
[Kein Betreff] - von Rumgucker - 25.11.2009, 11:12 AM
RE: - von audiosix - 25.11.2009, 11:13 AM
[Kein Betreff] - von obamaimladen - 25.11.2009, 11:17 AM
RE: - von audiosix - 25.11.2009, 11:17 AM
RE: - von audiosix - 25.11.2009, 11:18 AM
RE: RE: - von Rumgucker - 25.11.2009, 11:18 AM
RE: RE: RE: - von audiosix - 25.11.2009, 11:20 AM
RE: RE: - von Rumgucker - 25.11.2009, 11:22 AM
[Kein Betreff] - von obamaimladen - 25.11.2009, 11:22 AM
RE: RE: RE: RE: - von Rumgucker - 25.11.2009, 11:24 AM
[Kein Betreff] - von obamaimladen - 25.11.2009, 11:25 AM
RE: RE: RE: RE: RE: - von audiosix - 25.11.2009, 11:28 AM
RE: RE: RE: RE: RE: RE: - von Rumgucker - 25.11.2009, 11:30 AM
RE: - von audiosix - 25.11.2009, 11:30 AM
[Kein Betreff] - von obamaimladen - 25.11.2009, 11:48 AM
RE: - von audiosix - 25.11.2009, 11:50 AM
[Kein Betreff] - von Rumgucker - 25.11.2009, 11:55 AM
[Kein Betreff] - von obamaimladen - 25.11.2009, 11:56 AM
RE: - von obamaimladen - 25.11.2009, 12:04 PM
[Kein Betreff] - von Rumgucker - 25.11.2009, 12:10 PM
[Kein Betreff] - von obamaimladen - 25.11.2009, 12:17 PM
RE: - von obamaimladen - 25.11.2009, 12:17 PM
RE: RE: - von Rumgucker - 25.11.2009, 12:25 PM
RE: RE: RE: - von obamaimladen - 25.11.2009, 12:29 PM
RE: RE: RE: - von obamaimladen - 25.11.2009, 12:34 PM
RE: RE: RE: RE: - von Rumgucker - 25.11.2009, 12:38 PM
RE: RE: RE: RE: - von Rumgucker - 25.11.2009, 12:41 PM
Die Cascodeschaltung - von obamaimladen - 25.11.2009, 12:52 PM
[Kein Betreff] - von Rumgucker - 25.11.2009, 12:55 PM
[Kein Betreff] - von Rumgucker - 25.11.2009, 01:16 PM
[Kein Betreff] - von Rumgucker - 25.11.2009, 01:20 PM
[Kein Betreff] - von Rumgucker - 25.11.2009, 01:26 PM
[Kein Betreff] - von Rumzucker - 25.11.2009, 02:49 PM
[Kein Betreff] - von Rumgucker - 25.11.2009, 02:59 PM
[Kein Betreff] - von Rumzucker - 25.11.2009, 03:28 PM
[Kein Betreff] - von Rumgucker - 25.11.2009, 03:42 PM
[Kein Betreff] - von kahlo - 25.11.2009, 04:15 PM
[Kein Betreff] - von Gerd - 25.11.2009, 04:23 PM
RE: - von Rumgucker - 25.11.2009, 04:34 PM
RE: - von obamaimladen - 25.11.2009, 04:46 PM
[Kein Betreff] - von obamaimladen - 25.11.2009, 04:54 PM
RE: - von Rumgucker - 25.11.2009, 04:55 PM
[Kein Betreff] - von Rumzucker - 25.11.2009, 05:13 PM
[Kein Betreff] - von Rumgucker - 25.11.2009, 05:17 PM
[Kein Betreff] - von Rumzucker - 25.11.2009, 07:37 PM
[Kein Betreff] - von Rumgucker - 25.11.2009, 07:46 PM
[Kein Betreff] - von Rumzucker - 25.11.2009, 08:44 PM
[Kein Betreff] - von Rumgucker - 25.11.2009, 09:27 PM
RE: RE: RE: RE: RE: - von rumlungerer - 25.11.2009, 10:25 PM
RE: - von rumlungerer - 25.11.2009, 10:32 PM
RE: RE: - von rumlungerer - 25.11.2009, 10:35 PM
[Kein Betreff] - von Rumzucker - 26.11.2009, 01:07 AM
[Kein Betreff] - von Rumgucker - 26.11.2009, 09:50 AM
RE: - von obamaimladen - 26.11.2009, 10:19 AM
Kein Spam - von audiosix - 26.11.2009, 10:24 AM
RE: - von audiosix - 26.11.2009, 10:27 AM
[Kein Betreff] - von Rumgucker - 26.11.2009, 10:37 AM
RE: Kein Spam - von Rumgucker - 26.11.2009, 10:40 AM
[Kein Betreff] - von audiosix - 26.11.2009, 10:42 AM
RE: RE: - von obamaimladen - 26.11.2009, 10:44 AM
[Kein Betreff] - von Rumgucker - 26.11.2009, 10:52 AM
Simulation Stromverteilungsrauschen ... - von obamaimladen - 26.11.2009, 10:58 AM
[Kein Betreff] - von Rumgucker - 26.11.2009, 11:00 AM
RE: Simulation Stromverteilungsrauschen ... - von Rumgucker - 26.11.2009, 11:02 AM
[Kein Betreff] - von obamaimladen - 26.11.2009, 11:05 AM
RE: RE: Simulation Stromverteilungsrauschen ... - von obamaimladen - 26.11.2009, 11:07 AM
[Kein Betreff] - von Rumgucker - 26.11.2009, 11:10 AM
RE: RE: RE: - von audiosix - 26.11.2009, 11:13 AM
[Kein Betreff] - von Rumgucker - 26.11.2009, 11:15 AM
[Kein Betreff] - von Rumgucker - 26.11.2009, 12:32 PM
RE: - von obamaimladen - 26.11.2009, 12:51 PM
RE: - von rumlungerer - 26.11.2009, 12:53 PM
[Kein Betreff] - von Rumgucker - 26.11.2009, 01:02 PM
[Kein Betreff] - von Rumgucker - 26.11.2009, 01:27 PM
RE: - von obamaimladen - 26.11.2009, 01:32 PM
RE: RE: - von audiosix - 26.11.2009, 01:36 PM
[Kein Betreff] - von Rumgucker - 26.11.2009, 01:38 PM
[Kein Betreff] - von obamaimladen - 26.11.2009, 01:40 PM
RE: RE: RE: - von Rumgucker - 26.11.2009, 01:40 PM
RE: - von Rumgucker - 26.11.2009, 01:45 PM
RE: - von obamaimladen - 26.11.2009, 01:47 PM
[Kein Betreff] - von Rumgucker - 26.11.2009, 01:54 PM
RE: RE: RE: RE: - von audiosix - 26.11.2009, 01:54 PM
[Kein Betreff] - von Rumgucker - 26.11.2009, 01:56 PM
[Kein Betreff] - von obamaimladen - 26.11.2009, 01:58 PM
RE: - von Rumgucker - 26.11.2009, 01:59 PM
RE: - von Rumgucker - 26.11.2009, 02:09 PM
RE: RE: RE: RE: RE: - von Rumgucker - 26.11.2009, 02:16 PM
RE: - von Rumgucker - 26.11.2009, 02:24 PM
RE: RE: RE: RE: RE: RE: - von audiosix - 26.11.2009, 02:31 PM
[Kein Betreff] - von Rumgucker - 26.11.2009, 02:38 PM
[Kein Betreff] - von audiosix - 26.11.2009, 03:03 PM
[Kein Betreff] - von Rumgucker - 26.11.2009, 03:12 PM
[Kein Betreff] - von audiosix - 26.11.2009, 03:29 PM
[Kein Betreff] - von Rumgucker - 26.11.2009, 03:29 PM
RE: - von rumlungerer - 26.11.2009, 03:42 PM
[Kein Betreff] - von Rumgucker - 26.11.2009, 03:52 PM
RE: RE: - von Rumgucker - 26.11.2009, 03:56 PM
[Kein Betreff] - von rumlungerer - 26.11.2009, 03:58 PM
[Kein Betreff] - von Rumgucker - 26.11.2009, 04:02 PM
RE: RE: - von obamaimladen - 26.11.2009, 04:03 PM
[Kein Betreff] - von Rumgucker - 26.11.2009, 04:06 PM
[Kein Betreff] - von Rumgucker - 26.11.2009, 04:12 PM
[Kein Betreff] - von obamaimladen - 26.11.2009, 04:15 PM
[Kein Betreff] - von Rumgucker - 26.11.2009, 04:22 PM
[Kein Betreff] - von obamaimladen - 26.11.2009, 04:26 PM
[Kein Betreff] - von Rumgucker - 26.11.2009, 04:28 PM
[Kein Betreff] - von obamaimladen - 26.11.2009, 04:31 PM
[Kein Betreff] - von obamaimladen - 26.11.2009, 04:32 PM
RE: - von Rumgucker - 26.11.2009, 04:33 PM
[Kein Betreff] - von Rumgucker - 26.11.2009, 04:35 PM
RE: RE: - von obamaimladen - 26.11.2009, 04:39 PM
[Kein Betreff] - von Rumgucker - 26.11.2009, 04:42 PM
[Kein Betreff] - von obamaimladen - 26.11.2009, 04:47 PM
[Kein Betreff] - von Rumgucker - 26.11.2009, 04:48 PM
RE: - von Rumgucker - 26.11.2009, 04:50 PM
[Kein Betreff] - von Rumgucker - 26.11.2009, 04:53 PM
[Kein Betreff] - von obamaimladen - 26.11.2009, 04:58 PM
[Kein Betreff] - von Rumgucker - 26.11.2009, 05:02 PM
[Kein Betreff] - von kahlo - 26.11.2009, 05:15 PM
[Kein Betreff] - von Rumgucker - 26.11.2009, 05:25 PM
[Kein Betreff] - von obamaimladen - 26.11.2009, 05:35 PM
[Kein Betreff] - von Rumgucker - 26.11.2009, 05:43 PM
[Kein Betreff] - von voltwide - 26.11.2009, 06:06 PM
[Kein Betreff] - von Rumgucker - 26.11.2009, 06:09 PM
[Kein Betreff] - von obamaimladen - 26.11.2009, 06:12 PM
[Kein Betreff] - von Rumgucker - 26.11.2009, 06:18 PM
[Kein Betreff] - von Rumgucker - 26.11.2009, 06:22 PM
[Kein Betreff] - von obamaimladen - 26.11.2009, 06:25 PM
[Kein Betreff] - von audiosix - 26.11.2009, 08:26 PM
RE: - von audiosix - 26.11.2009, 08:29 PM
RE: - von Rumgucker - 26.11.2009, 08:35 PM
RE: - von kahlo - 26.11.2009, 09:07 PM
RE: - von audiosix - 27.11.2009, 08:03 AM
[Kein Betreff] - von obamaimladen - 27.11.2009, 09:40 AM
[Kein Betreff] - von Rumgucker - 27.11.2009, 09:50 AM
[Kein Betreff] - von audiosix - 27.11.2009, 09:53 AM
[Kein Betreff] - von obamaimladen - 27.11.2009, 09:55 AM
[Kein Betreff] - von Rumgucker - 27.11.2009, 09:58 AM
RE: - von Rumgucker - 27.11.2009, 10:01 AM
[Kein Betreff] - von Rumgucker - 27.11.2009, 10:14 AM
[Kein Betreff] - von audiosix - 27.11.2009, 10:20 AM
[Kein Betreff] - von Rumgucker - 27.11.2009, 10:22 AM
RE: RE: - von kahlo - 27.11.2009, 10:24 AM
[Kein Betreff] - von Rumgucker - 27.11.2009, 10:27 AM
[Kein Betreff] - von obamaimladen - 27.11.2009, 10:28 AM
RE: RE: RE: - von rumlungerer - 27.11.2009, 10:55 AM
[Kein Betreff] - von Rumgucker - 27.11.2009, 11:21 AM
[Kein Betreff] - von obamaimladen - 27.11.2009, 11:22 AM
RE: - von obamaimladen - 27.11.2009, 11:23 AM
[Kein Betreff] - von Rumgucker - 27.11.2009, 11:29 AM
[Kein Betreff] - von obamaimladen - 27.11.2009, 11:31 AM
[Kein Betreff] - von Rumgucker - 27.11.2009, 11:45 AM
[Kein Betreff] - von kahlo - 27.11.2009, 11:49 AM
[Kein Betreff] - von obamaimladen - 27.11.2009, 11:50 AM
[Kein Betreff] - von Rumgucker - 27.11.2009, 11:51 AM
[Kein Betreff] - von obamaimladen - 27.11.2009, 12:05 PM
[Kein Betreff] - von Rumgucker - 27.11.2009, 12:14 PM
RE: - von rumlungerer - 27.11.2009, 12:29 PM
RE: RE: - von Rumgucker - 27.11.2009, 12:37 PM
[Kein Betreff] - von Rumgucker - 27.11.2009, 12:39 PM
RE: - von rumlungerer - 27.11.2009, 05:31 PM
[Kein Betreff] - von Rumgucker - 27.11.2009, 05:35 PM
[Kein Betreff] - von Rumgucker - 27.11.2009, 05:38 PM
[Kein Betreff] - von Rumgucker - 27.11.2009, 05:48 PM
[Kein Betreff] - von Rumgucker - 27.11.2009, 07:19 PM
RE: - von Gerd - 30.11.2009, 08:44 AM
[Kein Betreff] - von kahlo - 30.11.2009, 08:53 AM
[Kein Betreff] - von audiosix - 30.11.2009, 09:10 AM
[Kein Betreff] - von kahlo - 30.11.2009, 09:17 AM
[Kein Betreff] - von Rumgucker - 30.11.2009, 09:42 AM
RE: - von Gerd - 30.11.2009, 09:55 AM
RE: - von Gerd - 30.11.2009, 09:56 AM
[Kein Betreff] - von kahlo - 30.11.2009, 10:13 AM
[Kein Betreff] - von Rumgucker - 30.11.2009, 10:14 AM
RE: - von Gerd - 30.11.2009, 10:33 AM
[Kein Betreff] - von Rumgucker - 30.11.2009, 10:39 AM
ETF ... Neue Schaltungstechnik ... - von obamaimladen - 30.11.2009, 11:06 AM
RE: - von Gerd - 30.11.2009, 11:12 AM
RE: RE: - von obamaimladen - 30.11.2009, 11:18 AM
Kaskode - von audiosix - 30.11.2009, 11:36 AM
RE: RE: RE: - von Gerd - 30.11.2009, 11:41 AM
RE: Kaskode - von obamaimladen - 30.11.2009, 11:43 AM
RE: RE: Kaskode - von Gerd - 30.11.2009, 11:50 AM
RE: RE: - von Rumgucker - 30.11.2009, 12:15 PM
RE: RE: - von kahlo - 30.11.2009, 12:24 PM
[Kein Betreff] - von obamaimladen - 30.11.2009, 12:33 PM
RE: - von obamaimladen - 30.11.2009, 12:52 PM
[Kein Betreff] - von Rumgucker - 30.11.2009, 12:53 PM
[Kein Betreff] - von Rumgucker - 30.11.2009, 01:10 PM
RE: - von Gerd - 30.11.2009, 01:41 PM
[Kein Betreff] - von obamaimladen - 30.11.2009, 01:46 PM
Grundlagen Röhrentechnik ... - von obamaimladen - 30.11.2009, 01:58 PM
RE: Grundlagen Röhrentechnik ... - von Gerd - 30.11.2009, 02:05 PM
[Kein Betreff] - von Rumgucker - 30.11.2009, 02:19 PM
RE: RE: Grundlagen Röhrentechnik ... - von obamaimladen - 30.11.2009, 04:53 PM
RE: RE: RE: Grundlagen Röhrentechnik ... - von Gerd - 30.11.2009, 05:46 PM
RE: - von obamaimladen - 30.11.2009, 05:48 PM
[Kein Betreff] - von Rumgucker - 30.11.2009, 05:59 PM
[Kein Betreff] - von Rumgucker - 30.11.2009, 06:02 PM
[Kein Betreff] - von Gerd - 30.11.2009, 06:11 PM
RE: - von Gerd - 30.11.2009, 06:11 PM
[Kein Betreff] - von Rumgucker - 30.11.2009, 06:13 PM
RE: RE: - von Rumgucker - 30.11.2009, 06:14 PM
RE: - von Rumgucker - 30.11.2009, 06:18 PM
[Kein Betreff] - von Rumzucker - 30.11.2009, 06:41 PM
[Kein Betreff] - von Rumgucker - 30.11.2009, 06:43 PM
RE: RE: - von Gerd - 30.11.2009, 06:58 PM
[Kein Betreff] - von Rumzucker - 30.11.2009, 07:00 PM
[Kein Betreff] - von obamaimladen - 30.11.2009, 07:10 PM
[Kein Betreff] - von Rumgucker - 30.11.2009, 07:10 PM
[Kein Betreff] - von Rumzucker - 30.11.2009, 07:13 PM
RE: - von Rumgucker - 30.11.2009, 07:16 PM
RE: - von Rumgucker - 30.11.2009, 07:19 PM
RE: - von obamaimladen - 30.11.2009, 07:32 PM
RE: RE: - von Gerd - 30.11.2009, 07:44 PM
[Kein Betreff] - von Rumgucker - 30.11.2009, 07:47 PM
RE: - von Gerd - 30.11.2009, 07:49 PM
[Kein Betreff] - von Rumgucker - 30.11.2009, 07:57 PM
RE: - von Gerd - 30.11.2009, 07:58 PM
[Kein Betreff] - von Rumgucker - 30.11.2009, 07:59 PM
RE: - von Gerd - 30.11.2009, 08:12 PM
RE: RE: - von obamaimladen - 30.11.2009, 08:14 PM
[Kein Betreff] - von Rumgucker - 30.11.2009, 08:16 PM
RE: - von Gerd - 30.11.2009, 08:18 PM
[Kein Betreff] - von Rumgucker - 30.11.2009, 08:20 PM
RE: RE: RE: - von Gerd - 30.11.2009, 08:20 PM
RE: Wurde schon vorgestellt ... - von obamaimladen - 30.11.2009, 08:23 PM
[Kein Betreff] - von Rumgucker - 30.11.2009, 08:25 PM
RE: RE: Wurde schon vorgestellt ... - von Rumgucker - 30.11.2009, 08:29 PM
RE: - von Gerd - 30.11.2009, 08:37 PM
RE: - von Gerd - 30.11.2009, 08:41 PM
[Kein Betreff] - von Rumgucker - 30.11.2009, 08:41 PM
RE: RE: - von Rumgucker - 30.11.2009, 08:42 PM
RE: - von Gerd - 30.11.2009, 08:42 PM
[Kein Betreff] - von Rumgucker - 30.11.2009, 08:45 PM
RE: RE: RE: - von Gerd - 30.11.2009, 08:46 PM
RE: RE: Wurde schon vorgestellt ... - von Gerd - 30.11.2009, 08:48 PM
RE: - von Gerd - 30.11.2009, 08:50 PM
[Kein Betreff] - von Rumgucker - 30.11.2009, 08:50 PM
RE: RE: RE: Wurde schon vorgestellt ... - von Rumgucker - 30.11.2009, 08:52 PM
RE: RE: - von Rumgucker - 30.11.2009, 08:53 PM
RE: - von Gerd - 30.11.2009, 09:09 PM
RE: RE: RE: - von Gerd - 30.11.2009, 09:19 PM
[Kein Betreff] - von kahlo - 30.11.2009, 10:47 PM
RE: RE: - von kahlo - 30.11.2009, 10:49 PM
RE: RE: - von audiosix - 01.12.2009, 07:43 AM
RE: - von Gerd - 01.12.2009, 08:30 AM
[Kein Betreff] - von Rumgucker - 01.12.2009, 09:47 AM
[Kein Betreff] - von kahlo - 01.12.2009, 09:55 AM
[Kein Betreff] - von audiosix - 01.12.2009, 10:03 AM
[Kein Betreff] - von obamaimladen - 01.12.2009, 10:06 AM
RE: - von Rumgucker - 01.12.2009, 10:06 AM
RE: - von Rumgucker - 01.12.2009, 10:11 AM
[Kein Betreff] - von audiosix - 01.12.2009, 10:24 AM
[Kein Betreff] - von kahlo - 01.12.2009, 10:35 AM
[Kein Betreff] - von audiosix - 01.12.2009, 10:45 AM
[Kein Betreff] - von Rumgucker - 01.12.2009, 10:59 AM
[Kein Betreff] - von audiosix - 01.12.2009, 11:12 AM
[Kein Betreff] - von Rumgucker - 01.12.2009, 11:18 AM
[Kein Betreff] - von audiosix - 01.12.2009, 11:36 AM
[Kein Betreff] - von Rumgucker - 01.12.2009, 11:42 AM
RE: - von Rumgucker - 01.12.2009, 11:46 AM
[Kein Betreff] - von audiosix - 01.12.2009, 11:47 AM
RE: - von Rumgucker - 01.12.2009, 11:52 AM
[Kein Betreff] - von Rumgucker - 01.12.2009, 11:54 AM
RE: RE: - von audiosix - 01.12.2009, 12:01 PM
[Kein Betreff] - von Rumgucker - 01.12.2009, 12:07 PM
[Kein Betreff] - von audiosix - 01.12.2009, 12:12 PM
RE: - von Gerd - 01.12.2009, 12:19 PM
RE: - von Gerd - 01.12.2009, 12:34 PM
[Kein Betreff] - von Rumgucker - 01.12.2009, 12:35 PM
[Kein Betreff] - von Rumgucker - 01.12.2009, 12:39 PM
[Kein Betreff] - von Rumgucker - 01.12.2009, 12:58 PM
RE: - von Gerd - 01.12.2009, 01:01 PM
RE: - von obamaimladen - 01.12.2009, 01:04 PM
[Kein Betreff] - von Rumgucker - 01.12.2009, 01:10 PM
[Kein Betreff] - von kahlo - 01.12.2009, 01:19 PM
RE: - von kahlo - 01.12.2009, 01:26 PM
[Kein Betreff] - von obamaimladen - 01.12.2009, 01:27 PM
RE: - von Rumgucker - 01.12.2009, 01:32 PM
RE: - von Rumgucker - 01.12.2009, 01:41 PM
[Kein Betreff] - von Rumgucker - 01.12.2009, 01:47 PM
RE: - von Gerd - 01.12.2009, 01:50 PM
RE: RE: - von Rumgucker - 01.12.2009, 01:52 PM
RE: RE: - von Rumgucker - 01.12.2009, 01:54 PM
[Kein Betreff] - von Rumgucker - 01.12.2009, 02:05 PM
RE: RE: - von Gerd - 01.12.2009, 02:06 PM
RE: RE: RE: - von kahlo - 01.12.2009, 02:09 PM
[Kein Betreff] - von Rumgucker - 01.12.2009, 02:11 PM
RE: RE: RE: - von Gerd - 01.12.2009, 02:49 PM
[Kein Betreff] - von Rumgucker - 01.12.2009, 02:59 PM
RE: RE: RE: RE: - von Rumgucker - 01.12.2009, 03:04 PM
[Kein Betreff] - von Rumgucker - 01.12.2009, 03:08 PM
RE: - von Gerd - 01.12.2009, 03:16 PM
[Kein Betreff] - von Rumgucker - 01.12.2009, 03:27 PM
RE: - von rumlungerer - 01.12.2009, 03:30 PM
[Kein Betreff] - von Rumgucker - 01.12.2009, 03:34 PM
RE: RE: - von audiosix - 01.12.2009, 03:49 PM
RE: RE: RE: - von kahlo - 01.12.2009, 03:51 PM
[Kein Betreff] - von Rumgucker - 01.12.2009, 04:00 PM
RE: RE: RE: RE: - von audiosix - 01.12.2009, 04:12 PM
RE: - von Gerd - 01.12.2009, 04:16 PM
[Kein Betreff] - von Rumgucker - 01.12.2009, 04:17 PM
RE: RE: - von Rumgucker - 01.12.2009, 04:18 PM
RE: RE: RE: RE: RE: - von kahlo - 01.12.2009, 04:25 PM
RE: RE: RE: - von Gerd - 01.12.2009, 04:26 PM
[Kein Betreff] - von Rumgucker - 01.12.2009, 04:29 PM
RE: RE: RE: RE: RE: RE: - von Rumgucker - 01.12.2009, 04:32 PM
[Kein Betreff] - von kahlo - 01.12.2009, 04:36 PM
[Kein Betreff] - von audiosix - 01.12.2009, 04:44 PM
RE: RE: RE: - von rumlungerer - 01.12.2009, 05:13 PM
[Kein Betreff] - von Rumgucker - 01.12.2009, 05:30 PM
RE: RE: RE: RE: - von Gerd - 01.12.2009, 05:33 PM
RE: - von Gerd - 01.12.2009, 05:35 PM
[Kein Betreff] - von Rumgucker - 01.12.2009, 05:46 PM
RE: - von Gerd - 01.12.2009, 05:55 PM
[Kein Betreff] - von Rumgucker - 01.12.2009, 05:58 PM
RE: - von Gerd - 01.12.2009, 06:00 PM
[Kein Betreff] - von Rumgucker - 01.12.2009, 06:01 PM
Ich habe auch mal gemessen ... - von obamaimladen - 01.12.2009, 06:04 PM
[Kein Betreff] - von Rumgucker - 01.12.2009, 06:09 PM
[Kein Betreff] - von obamaimladen - 01.12.2009, 06:36 PM
[Kein Betreff] - von Rumgucker - 01.12.2009, 06:44 PM
RE: - von rumlungerer - 01.12.2009, 08:13 PM
[Kein Betreff] - von Rumgucker - 01.12.2009, 08:16 PM
[Kein Betreff] - von kahlo - 01.12.2009, 09:36 PM
RE: - von rumlungerer - 01.12.2009, 09:36 PM
RE: - von Rumgucker - 02.12.2009, 09:51 AM
RE: - von Rumgucker - 02.12.2009, 10:06 AM
[Kein Betreff] - von Rumgucker - 02.12.2009, 10:17 AM
[Kein Betreff] - von Rumgucker - 02.12.2009, 10:26 AM
[Kein Betreff] - von Rumgucker - 02.12.2009, 10:39 AM
[Kein Betreff] - von Rumgucker - 02.12.2009, 10:41 AM
[Kein Betreff] - von audiosix - 02.12.2009, 10:43 AM
[Kein Betreff] - von kahlo - 02.12.2009, 10:49 AM
[Kein Betreff] - von Rumgucker - 02.12.2009, 10:51 AM
[Kein Betreff] - von audiosix - 02.12.2009, 10:57 AM
RE: - von Rumgucker - 02.12.2009, 11:01 AM
RE: - von Rumgucker - 02.12.2009, 11:02 AM
[Kein Betreff] - von obamaimladen - 02.12.2009, 11:13 AM
[Kein Betreff] - von audiosix - 02.12.2009, 11:17 AM
[Kein Betreff] - von audiosix - 02.12.2009, 11:19 AM
[Kein Betreff] - von Rumgucker - 02.12.2009, 11:34 AM
[Kein Betreff] - von Rumgucker - 02.12.2009, 11:39 AM
[Kein Betreff] - von audiosix - 02.12.2009, 11:50 AM
[Kein Betreff] - von obamaimladen - 02.12.2009, 11:55 AM
[Kein Betreff] - von Rumgucker - 02.12.2009, 11:58 AM
RE: - von obamaimladen - 02.12.2009, 12:04 PM
[Kein Betreff] - von audiosix - 02.12.2009, 12:12 PM
RE: - von audiosix - 02.12.2009, 12:14 PM
RE: - von obamaimladen - 02.12.2009, 12:25 PM
RE: RE: - von kahlo - 02.12.2009, 01:31 PM
[Kein Betreff] - von Rumgucker - 02.12.2009, 01:38 PM
RE: RE: RE: - von Rumgucker - 02.12.2009, 01:40 PM
[Kein Betreff] - von obamaimladen - 02.12.2009, 01:46 PM
[Kein Betreff] - von Rumgucker - 02.12.2009, 02:15 PM
RE: - von Rumgucker - 02.12.2009, 02:18 PM
RE: RE: RE: RE: - von Rumgucker - 02.12.2009, 02:22 PM
[Kein Betreff] - von kahlo - 02.12.2009, 02:23 PM
RE: RE: - von Gerd - 02.12.2009, 02:24 PM
RE: - von Gerd - 02.12.2009, 02:48 PM
[Kein Betreff] - von kahlo - 02.12.2009, 02:56 PM
RE: - von Rumgucker - 02.12.2009, 02:56 PM
RE: - von Rumgucker - 02.12.2009, 02:57 PM
[Kein Betreff] - von Rumgucker - 02.12.2009, 03:00 PM
RE: RE: - von Rumgucker - 02.12.2009, 03:05 PM
[Kein Betreff] - von obamaimladen - 02.12.2009, 03:10 PM
RE: RE: RE: - von obamaimladen - 02.12.2009, 03:14 PM
RE: - von Rumgucker - 02.12.2009, 03:19 PM
RE: RE: RE: RE: - von Rumgucker - 02.12.2009, 03:21 PM
RE: - von Gerd - 02.12.2009, 03:25 PM
RE: RE: - von Gerd - 02.12.2009, 03:27 PM
RE: RE: RE: RE: - von Gerd - 02.12.2009, 03:29 PM
RE: RE: RE: RE: RE: - von rumlungerer - 02.12.2009, 03:40 PM
RE: RE: - von Rumgucker - 02.12.2009, 03:40 PM
RE: RE: RE: - von Rumgucker - 02.12.2009, 03:43 PM
RE: RE: RE: RE: - von rumlungerer - 02.12.2009, 03:50 PM
[Kein Betreff] - von Rumgucker - 02.12.2009, 03:58 PM
RE: - von rumlungerer - 02.12.2009, 04:03 PM
[Kein Betreff] - von Rumgucker - 02.12.2009, 04:09 PM
[Kein Betreff] - von audiosix - 02.12.2009, 04:17 PM
[Kein Betreff] - von kahlo - 02.12.2009, 04:28 PM
[Kein Betreff] - von audiosix - 02.12.2009, 04:35 PM
[Kein Betreff] - von Rumgucker - 02.12.2009, 04:39 PM
RE: - von kahlo - 02.12.2009, 04:47 PM
RE: RE: RE: RE: RE: - von obamaimladen - 02.12.2009, 05:00 PM
[Kein Betreff] - von Rumgucker - 02.12.2009, 05:08 PM
Stand der Technik - von obamaimladen - 02.12.2009, 06:11 PM
[Kein Betreff] - von rumlungerer - 02.12.2009, 06:18 PM
RE: Stand der Technik - von rumlungerer - 02.12.2009, 06:24 PM
RE: Stand der Technik - von Gerd - 02.12.2009, 06:28 PM
[Kein Betreff] - von Rumgucker - 02.12.2009, 06:30 PM
[Kein Betreff] - von Rumgucker - 02.12.2009, 06:32 PM
RE: RE: Stand der Technik - von Rumgucker - 02.12.2009, 06:36 PM
RE: - von Gerd - 02.12.2009, 06:41 PM
RE: RE: Stand der Technik - von obamaimladen - 02.12.2009, 06:49 PM
[Kein Betreff] - von Rumgucker - 02.12.2009, 06:49 PM
RE: - von rumlungerer - 02.12.2009, 06:53 PM
[Kein Betreff] - von obamaimladen - 02.12.2009, 07:04 PM
[Kein Betreff] - von Rumgucker - 02.12.2009, 07:04 PM
RE: - von rumlungerer - 02.12.2009, 07:20 PM
[Kein Betreff] - von Rumgucker - 02.12.2009, 07:22 PM
RE: RE: RE: Stand der Technik - von Gerd - 02.12.2009, 07:34 PM
RE: - von Gerd - 02.12.2009, 07:39 PM
RE: - von Gerd - 02.12.2009, 07:42 PM
[Kein Betreff] - von Rumgucker - 02.12.2009, 07:46 PM
RE: RE: - von Rumgucker - 02.12.2009, 07:51 PM
RE: - von Gerd - 02.12.2009, 08:04 PM
[Kein Betreff] - von Rumgucker - 02.12.2009, 08:15 PM
RE: RE: - von obamaimladen - 02.12.2009, 08:17 PM
[Kein Betreff] - von Rumgucker - 02.12.2009, 08:57 PM
RE: - von rumlungerer - 02.12.2009, 08:59 PM
[Kein Betreff] - von Rumgucker - 02.12.2009, 08:59 PM
[Kein Betreff] - von Rumgucker - 02.12.2009, 09:03 PM
RE: RE: - von Rumgucker - 02.12.2009, 09:04 PM
RE: RE: RE: - von rumlungerer - 02.12.2009, 09:22 PM
RE: RE: RE: - von Gerd - 02.12.2009, 09:23 PM
[Kein Betreff] - von Rumgucker - 02.12.2009, 09:34 PM
[Kein Betreff] - von Rumgucker - 02.12.2009, 09:45 PM
RE: RE: RE: RE: - von Rumgucker - 02.12.2009, 09:47 PM
RE: - von diabolos - 02.12.2009, 09:48 PM
[Kein Betreff] - von Rumgucker - 02.12.2009, 09:53 PM
RE: - von Gerd - 03.12.2009, 08:02 AM
RE: RE: - von kahlo - 03.12.2009, 08:43 AM
[Kein Betreff] - von Rumgucker - 03.12.2009, 09:19 AM
Milestone: Franks Patent auf dem ETF - von Rumgucker - 03.12.2009, 09:21 AM
[Kein Betreff] - von audiosix - 03.12.2009, 09:27 AM
[Kein Betreff] - von obamaimladen - 03.12.2009, 09:37 AM
[Kein Betreff] - von audiosix - 03.12.2009, 09:53 AM
RE: - von Gerd - 03.12.2009, 10:08 AM
RE: - von kahlo - 03.12.2009, 10:14 AM
[Kein Betreff] - von Rumgucker - 03.12.2009, 10:32 AM
[Kein Betreff] - von kahlo - 03.12.2009, 10:43 AM
[Kein Betreff] - von Rumgucker - 03.12.2009, 10:47 AM
[Kein Betreff] - von kahlo - 03.12.2009, 11:00 AM
[Kein Betreff] - von Rumgucker - 03.12.2009, 11:03 AM
[Kein Betreff] - von Rumgucker - 03.12.2009, 11:08 AM
[Kein Betreff] - von Rumgucker - 03.12.2009, 12:03 PM
[Kein Betreff] - von obamaimladen - 03.12.2009, 12:53 PM
[Kein Betreff] - von Rumgucker - 03.12.2009, 12:55 PM
RE: - von Rumgucker - 03.12.2009, 01:07 PM
[Kein Betreff] - von Rumgucker - 03.12.2009, 01:10 PM
[Kein Betreff] - von obamaimladen - 03.12.2009, 01:16 PM
RE: RE: - von obamaimladen - 03.12.2009, 01:18 PM
RE: - von Rumgucker - 03.12.2009, 01:20 PM
RE: RE: RE: - von Rumgucker - 03.12.2009, 01:22 PM
RE: RE: - von obamaimladen - 03.12.2009, 01:24 PM
[Kein Betreff] - von Rumgucker - 03.12.2009, 01:27 PM
[Kein Betreff] - von Rumgucker - 03.12.2009, 01:33 PM
RE: - von Gerd - 03.12.2009, 01:34 PM
[Kein Betreff] - von Rumgucker - 03.12.2009, 01:37 PM
RE: - von obamaimladen - 03.12.2009, 01:41 PM
RE: - von Gerd - 03.12.2009, 01:46 PM
RE: RE: - von obamaimladen - 03.12.2009, 01:49 PM
RE: RE: - von Rumgucker - 03.12.2009, 01:50 PM
RE: RE: RE: - von Gerd - 03.12.2009, 01:51 PM
[Kein Betreff] - von Rumgucker - 03.12.2009, 01:53 PM
RE: RE: RE: RE: - von Rumgucker - 03.12.2009, 01:54 PM
RE: - von Gerd - 03.12.2009, 02:03 PM
RE: RE: - von obamaimladen - 03.12.2009, 02:09 PM
[Kein Betreff] - von Rumgucker - 03.12.2009, 02:10 PM
RE: - von obamaimladen - 03.12.2009, 02:12 PM
RE: RE: RE: - von Rumgucker - 03.12.2009, 02:12 PM
RE: RE: RE: - von Gerd - 03.12.2009, 02:14 PM
RE: RE: - von Rumgucker - 03.12.2009, 02:15 PM
RE: RE: RE: RE: - von Gerd - 03.12.2009, 02:15 PM
RE: RE: RE: RE: - von Rumgucker - 03.12.2009, 02:15 PM
RE: RE: RE: RE: RE: - von Rumgucker - 03.12.2009, 02:17 PM
RE: RE: RE: - von Gerd - 03.12.2009, 02:19 PM
[Kein Betreff] - von Rumgucker - 03.12.2009, 02:20 PM
RE: RE: RE: RE: RE: - von obamaimladen - 03.12.2009, 02:21 PM
RE: RE: RE: RE: - von Rumgucker - 03.12.2009, 02:24 PM
[Kein Betreff] - von Rumgucker - 03.12.2009, 02:29 PM
[Kein Betreff] - von Rumgucker - 03.12.2009, 02:30 PM
[Kein Betreff] - von Rumgucker - 03.12.2009, 02:33 PM
[Kein Betreff] - von kahlo - 03.12.2009, 02:35 PM
[Kein Betreff] - von Rumgucker - 03.12.2009, 02:44 PM
RE: - von kahlo - 03.12.2009, 02:52 PM
[Kein Betreff] - von Rumgucker - 03.12.2009, 02:54 PM
[Kein Betreff] - von Rumgucker - 03.12.2009, 03:00 PM
[Kein Betreff] - von kahlo - 03.12.2009, 03:27 PM
[Kein Betreff] - von Rumgucker - 03.12.2009, 04:06 PM
RE: - von rumlungerer - 03.12.2009, 04:20 PM
[Kein Betreff] - von audiosix - 03.12.2009, 04:39 PM
[Kein Betreff] - von Rumgucker - 03.12.2009, 04:46 PM
RE: - von Rumgucker - 03.12.2009, 04:50 PM
[Kein Betreff] - von audiosix - 03.12.2009, 05:34 PM
[Kein Betreff] - von Rumgucker - 03.12.2009, 05:45 PM
[Kein Betreff] - von obamaimladen - 03.12.2009, 06:49 PM
[Kein Betreff] - von Rumgucker - 03.12.2009, 06:56 PM
[Kein Betreff] - von obamaimladen - 03.12.2009, 06:57 PM
[Kein Betreff] - von Rumgucker - 03.12.2009, 07:09 PM
[Kein Betreff] - von Rumgucker - 03.12.2009, 07:10 PM
[Kein Betreff] - von Rumgucker - 03.12.2009, 07:14 PM
[Kein Betreff] - von Rumgucker - 03.12.2009, 07:18 PM
[Kein Betreff] - von obamaimladen - 03.12.2009, 07:21 PM
[Kein Betreff] - von Rumgucker - 03.12.2009, 07:35 PM
[Kein Betreff] - von Rumgucker - 04.12.2009, 09:48 AM
[Kein Betreff] - von rumlungerer - 04.12.2009, 10:01 AM
RE: - von Rumgucker - 04.12.2009, 10:11 AM
[Kein Betreff] - von rumlungerer - 04.12.2009, 10:20 AM
[Kein Betreff] - von Rumgucker - 04.12.2009, 10:25 AM
[Kein Betreff] - von rumlungerer - 04.12.2009, 10:34 AM
[Kein Betreff] - von Rumgucker - 04.12.2009, 10:43 AM
[Kein Betreff] - von obamaimladen - 04.12.2009, 11:04 AM
RE: - von rumlungerer - 04.12.2009, 11:12 AM
[Kein Betreff] - von Rumgucker - 04.12.2009, 11:18 AM
[Kein Betreff] - von Rumgucker - 04.12.2009, 11:41 AM
[Kein Betreff] - von Rumgucker - 04.12.2009, 01:18 PM
RE: - von rumlungerer - 04.12.2009, 03:11 PM
RE: - von Rumgucker - 04.12.2009, 03:53 PM
[Kein Betreff] - von obamaimladen - 04.12.2009, 04:22 PM
[Kein Betreff] - von Rumgucker - 04.12.2009, 04:30 PM
Unter uns ... - von obamaimladen - 04.12.2009, 04:40 PM
[Kein Betreff] - von Rumgucker - 04.12.2009, 04:53 PM
Unter uns ... - von obamaimladen - 04.12.2009, 05:00 PM
[Kein Betreff] - von kahlo - 04.12.2009, 05:15 PM
[Kein Betreff] - von Rumgucker - 04.12.2009, 05:20 PM
Zum Thema - von obamaimladen - 04.12.2009, 07:18 PM
[Kein Betreff] - von obamaimladen - 04.12.2009, 08:04 PM
[Kein Betreff] - von Rumgucker - 04.12.2009, 08:08 PM
RE: Unter uns ... - von Gerd - 04.12.2009, 08:18 PM
RE: RE: Unter uns ... - von Rumgucker - 04.12.2009, 08:23 PM
RE: RE: RE: Unter uns ... - von rumlungerer - 04.12.2009, 11:28 PM
[Kein Betreff] - von Rumgucker - 05.12.2009, 09:34 AM
[Kein Betreff] - von audiosix - 05.12.2009, 09:38 AM
[Kein Betreff] - von Rumgucker - 05.12.2009, 09:39 AM
[Kein Betreff] - von obamaimladen - 05.12.2009, 10:35 AM
RE: Unter uns ... - von audiosix - 05.12.2009, 11:10 AM
[Kein Betreff] - von Rumgucker - 05.12.2009, 11:16 AM
[Kein Betreff] - von audiosix - 05.12.2009, 11:36 AM
[Kein Betreff] - von Rumgucker - 05.12.2009, 11:38 AM
[Kein Betreff] - von audiosix - 05.12.2009, 11:50 AM
[Kein Betreff] - von Rumgucker - 05.12.2009, 12:01 PM
@ audiosix - von obamaimladen - 05.12.2009, 12:03 PM
Zecke ... - von obamaimladen - 05.12.2009, 12:13 PM
[Kein Betreff] - von Rumgucker - 05.12.2009, 12:14 PM
[Kein Betreff] - von rumlungerer - 06.12.2009, 12:00 AM
[Kein Betreff] - von Rumgucker - 06.12.2009, 10:32 AM
[Kein Betreff] - von obamaimladen - 06.12.2009, 11:08 AM
RE: - von Gerd - 06.12.2009, 12:34 PM
RE: - von rumlungerer - 06.12.2009, 02:11 PM
RE: - von rumlungerer - 06.12.2009, 02:13 PM
[Kein Betreff] - von Rumgucker - 06.12.2009, 02:52 PM
RE: - von rumlungerer - 09.12.2009, 03:20 PM
[Kein Betreff] - von Rumgucker - 09.12.2009, 03:35 PM
[Kein Betreff] - von Rumgucker - 12.12.2009, 02:10 PM
RE: - von Gerd - 12.12.2009, 03:28 PM
[Kein Betreff] - von Rumgucker - 15.12.2009, 02:18 PM
[Kein Betreff] - von Gerd - 15.12.2009, 02:51 PM
RE: - von Rumgucker - 15.12.2009, 02:59 PM
[Kein Betreff] - von Rumgucker - 15.12.2009, 03:01 PM
[Kein Betreff] - von Rumgucker - 15.12.2009, 03:07 PM
[Kein Betreff] - von kahlo - 15.12.2009, 03:29 PM
[Kein Betreff] - von Rumzucker - 15.12.2009, 03:36 PM
[Kein Betreff] - von Rumgucker - 15.12.2009, 03:37 PM
[Kein Betreff] - von Rumgucker - 15.12.2009, 03:39 PM
RE: - von kahlo - 15.12.2009, 03:43 PM
[Kein Betreff] - von Rumgucker - 15.12.2009, 03:59 PM
RE: - von Gerd - 15.12.2009, 04:04 PM
[Kein Betreff] - von Rumgucker - 15.12.2009, 04:06 PM
RE: - von Gerd - 15.12.2009, 04:08 PM
[Kein Betreff] - von Rumgucker - 15.12.2009, 04:10 PM
RE: RE: - von Gerd - 15.12.2009, 04:13 PM
RE: - von Gerd - 15.12.2009, 04:16 PM
[Kein Betreff] - von Rumgucker - 15.12.2009, 04:16 PM
RE: RE: - von Rumgucker - 15.12.2009, 04:17 PM
So zaubert Frank - von obamaimladen - 15.12.2009, 04:23 PM
[Kein Betreff] - von Gerd - 15.12.2009, 04:27 PM
[Kein Betreff] - von Rumgucker - 15.12.2009, 04:32 PM
[Kein Betreff] - von Rumgucker - 15.12.2009, 04:36 PM
Vorsicht! - von obamaimladen - 15.12.2009, 04:45 PM
[Kein Betreff] - von Rumgucker - 15.12.2009, 04:45 PM
RE: - von Gerd - 15.12.2009, 04:49 PM
[Kein Betreff] - von obamaimladen - 15.12.2009, 04:49 PM
[Kein Betreff] - von Rumgucker - 15.12.2009, 05:02 PM
[Kein Betreff] - von obamaimladen - 15.12.2009, 05:10 PM
RE: - von Gerd - 15.12.2009, 05:23 PM
[Kein Betreff] - von Rumgucker - 15.12.2009, 05:30 PM
[Kein Betreff] - von Rumgucker - 15.12.2009, 05:32 PM
[Kein Betreff] - von Rumgucker - 15.12.2009, 05:35 PM
[Kein Betreff] - von Gerd - 15.12.2009, 05:44 PM
RE: - von kahlo - 15.12.2009, 05:49 PM
[Kein Betreff] - von Rumgucker - 15.12.2009, 05:49 PM
RE: RE: - von Rumgucker - 15.12.2009, 05:50 PM
[Kein Betreff] - von Rumgucker - 15.12.2009, 05:52 PM
[Kein Betreff] - von kahlo - 15.12.2009, 05:53 PM
[Kein Betreff] - von Rumgucker - 15.12.2009, 05:57 PM
[Kein Betreff] - von Rumgucker - 15.12.2009, 06:00 PM
[Kein Betreff] - von Rumgucker - 15.12.2009, 06:08 PM
RE: RE: - von Gerd - 15.12.2009, 06:17 PM
RE: - von Gerd - 15.12.2009, 06:18 PM
[Kein Betreff] - von Rumgucker - 15.12.2009, 06:28 PM
[Kein Betreff] - von Rumgucker - 15.12.2009, 07:09 PM
RE: - von Gerd - 15.12.2009, 07:24 PM
[Kein Betreff] - von Rumgucker - 15.12.2009, 07:48 PM
RE: - von Gerd - 15.12.2009, 08:03 PM
[Kein Betreff] - von Rumgucker - 15.12.2009, 08:06 PM
[Kein Betreff] - von Rumgucker - 15.12.2009, 08:09 PM
RE: - von Gerd - 15.12.2009, 08:09 PM
[Kein Betreff] - von Rumgucker - 15.12.2009, 08:10 PM
RE: - von Gerd - 15.12.2009, 08:12 PM
RE: RE: - von Rumgucker - 15.12.2009, 08:13 PM
RE: - von Gerd - 15.12.2009, 08:20 PM
RE: RE: RE: - von Gerd - 15.12.2009, 08:21 PM
[Kein Betreff] - von Gerd - 15.12.2009, 08:24 PM
[Kein Betreff] - von Rumgucker - 15.12.2009, 08:47 PM
[Kein Betreff] - von Rumgucker - 15.12.2009, 08:53 PM
RE: - von Gerd - 15.12.2009, 08:55 PM
RE: - von Gerd - 15.12.2009, 08:58 PM
RE: - von Gerd - 15.12.2009, 09:22 PM
[Kein Betreff] - von obamaimladen - 15.12.2009, 09:24 PM
[Kein Betreff] - von Rumgucker - 15.12.2009, 09:25 PM
RE: RE: - von Rumgucker - 15.12.2009, 09:25 PM
RE: - von Rumgucker - 15.12.2009, 09:26 PM
[Kein Betreff] - von Rumgucker - 16.12.2009, 09:21 AM
[Kein Betreff] - von Rumgucker - 16.12.2009, 09:32 AM
[Kein Betreff] - von kahlo - 16.12.2009, 10:26 AM
RE: - von Gerd - 16.12.2009, 10:26 AM
RE: - von Rumgucker - 16.12.2009, 10:32 AM
RE: RE: - von kahlo - 16.12.2009, 10:36 AM
[Kein Betreff] - von Rumgucker - 16.12.2009, 10:36 AM
RE: - von Gerd - 16.12.2009, 10:37 AM
RE: RE: RE: - von Rumgucker - 16.12.2009, 10:40 AM
RE: RE: - von Rumgucker - 16.12.2009, 10:41 AM
RE: RE: - von kahlo - 16.12.2009, 10:55 AM
[Kein Betreff] - von Rumgucker - 16.12.2009, 10:58 AM
RE: RE: RE: - von Gerd - 16.12.2009, 10:59 AM
[Kein Betreff] - von Rumgucker - 16.12.2009, 11:04 AM
RE: RE: RE: - von Gerd - 16.12.2009, 11:04 AM
[Kein Betreff] - von Rumgucker - 16.12.2009, 11:07 AM
RE: - von Gerd - 16.12.2009, 11:08 AM
[Kein Betreff] - von Rumgucker - 16.12.2009, 11:14 AM
RE: RE: RE: RE: - von kahlo - 16.12.2009, 11:15 AM
[Kein Betreff] - von obamaimladen - 16.12.2009, 11:17 AM
RE: RE: RE: RE: RE: - von Rumgucker - 16.12.2009, 11:31 AM
[Kein Betreff] - von Rumgucker - 16.12.2009, 11:36 AM
[Kein Betreff] - von obamaimladen - 16.12.2009, 11:42 AM
[Kein Betreff] - von Rumgucker - 16.12.2009, 11:49 AM
RE: - von kahlo - 16.12.2009, 01:01 PM
[Kein Betreff] - von Rumgucker - 16.12.2009, 01:15 PM
RE: - von Gerd - 16.12.2009, 01:20 PM
[Kein Betreff] - von Rumgucker - 16.12.2009, 01:30 PM
RE: RE: - von kahlo - 16.12.2009, 01:34 PM
[Kein Betreff] - von Rumgucker - 16.12.2009, 01:38 PM
RE: - von obamaimladen - 16.12.2009, 01:56 PM
Trioden wie Pentoden betreiben ... Hatten wir schon einmal ... - von obamaimladen - 16.12.2009, 01:59 PM
[Kein Betreff] - von Rumgucker - 16.12.2009, 02:44 PM
RE: - von Gerd - 16.12.2009, 03:28 PM
RE: - von Gerd - 16.12.2009, 03:38 PM
RE: - von Gerd - 16.12.2009, 03:40 PM
[Kein Betreff] - von Rumgucker - 16.12.2009, 04:01 PM
RE: - von Gerd - 16.12.2009, 04:37 PM
[Kein Betreff] - von Rumgucker - 16.12.2009, 04:44 PM
RE: - von Gerd - 16.12.2009, 04:55 PM
[Kein Betreff] - von Rumgucker - 16.12.2009, 05:32 PM
RE: - von Rumgucker - 16.12.2009, 05:34 PM
[Kein Betreff] - von Rumgucker - 16.12.2009, 05:38 PM
[Kein Betreff] - von Gerd - 16.12.2009, 05:44 PM
RE: - von Gerd - 16.12.2009, 05:56 PM
[Kein Betreff] - von Rumgucker - 16.12.2009, 05:56 PM
RE: - von Gerd - 16.12.2009, 06:00 PM
[Kein Betreff] - von Rumgucker - 16.12.2009, 06:09 PM
RE: - von Gerd - 16.12.2009, 07:18 PM
[Kein Betreff] - von Rumgucker - 16.12.2009, 07:43 PM
Cascode - von obamaimladen - 16.12.2009, 08:25 PM
[Kein Betreff] - von Rumgucker - 16.12.2009, 08:26 PM
[Kein Betreff] - von obamaimladen - 16.12.2009, 08:41 PM
[Kein Betreff] - von Rumgucker - 16.12.2009, 08:44 PM
[Kein Betreff] - von Rumgucker - 16.12.2009, 08:46 PM
RE: - von Rumgucker - 16.12.2009, 08:53 PM
[Kein Betreff] - von Rumgucker - 16.12.2009, 09:01 PM
[Kein Betreff] - von Rumgucker - 16.12.2009, 09:05 PM
[Kein Betreff] - von Rumgucker - 16.12.2009, 09:08 PM
[Kein Betreff] - von Rumgucker - 16.12.2009, 09:21 PM
[Kein Betreff] - von Rumgucker - 16.12.2009, 09:26 PM
RE: - von Gerd - 17.12.2009, 07:55 AM
[Kein Betreff] - von Rumgucker - 17.12.2009, 09:47 AM
[Kein Betreff] - von Rumgucker - 17.12.2009, 09:56 AM
[Kein Betreff] - von audiosix - 17.12.2009, 10:44 AM
RE: - von Gerd - 17.12.2009, 11:14 AM
RE: - von obamaimladen - 17.12.2009, 11:50 AM
RE: - von Rumgucker - 17.12.2009, 11:50 AM
[Kein Betreff] - von Rumgucker - 17.12.2009, 11:59 AM
Friis ... - von obamaimladen - 17.12.2009, 12:06 PM
RE: RE: - von audiosix - 17.12.2009, 12:18 PM
RE: RE: RE: - von Rumgucker - 17.12.2009, 12:35 PM
[Kein Betreff] - von Rumgucker - 17.12.2009, 12:39 PM
Von wegen Pentode ! - von obamaimladen - 17.12.2009, 12:41 PM
RE: Von wegen Pentode ! - von rumlungerer - 17.12.2009, 12:59 PM
[Kein Betreff] - von Rumgucker - 17.12.2009, 01:00 PM
RE: - von obamaimladen - 17.12.2009, 01:05 PM
RE: RE: Von wegen Pentode ! - von obamaimladen - 17.12.2009, 01:10 PM
[Kein Betreff] - von Rumgucker - 17.12.2009, 01:12 PM
[Kein Betreff] - von Rumgucker - 17.12.2009, 01:28 PM
[Kein Betreff] - von Rumgucker - 17.12.2009, 01:34 PM
[Kein Betreff] - von obamaimladen - 17.12.2009, 01:36 PM
[Kein Betreff] - von Rumgucker - 17.12.2009, 01:39 PM
[Kein Betreff] - von obamaimladen - 17.12.2009, 01:45 PM
RE: So zaubert Frank - von obamaimladen - 17.12.2009, 01:54 PM
[Kein Betreff] - von Rumgucker - 17.12.2009, 01:54 PM
[Kein Betreff] - von Rumgucker - 17.12.2009, 02:05 PM
[Kein Betreff] - von obamaimladen - 17.12.2009, 02:10 PM
[Kein Betreff] - von Rumgucker - 17.12.2009, 02:36 PM
RE: - von Gerd - 17.12.2009, 03:24 PM
[Kein Betreff] - von obamaimladen - 17.12.2009, 04:24 PM
[Kein Betreff] - von Rumgucker - 17.12.2009, 04:39 PM
RE: - von Gerd - 17.12.2009, 04:43 PM
[Kein Betreff] - von Rumgucker - 17.12.2009, 06:35 PM
[Kein Betreff] - von obamaimladen - 17.12.2009, 06:49 PM
[Kein Betreff] - von Rumgucker - 17.12.2009, 07:33 PM
mb - von obamaimladen - 17.12.2009, 07:40 PM
[Kein Betreff] - von Rumgucker - 17.12.2009, 07:49 PM
[Kein Betreff] - von obamaimladen - 17.12.2009, 08:06 PM
[Kein Betreff] - von Rumgucker - 17.12.2009, 08:10 PM
[Kein Betreff] - von audiosix - 17.12.2009, 08:10 PM
[Kein Betreff] - von Rumgucker - 17.12.2009, 08:16 PM
[Kein Betreff] - von Rumgucker - 17.12.2009, 08:22 PM
[Kein Betreff] - von audiosix - 17.12.2009, 08:24 PM
[Kein Betreff] - von obamaimladen - 17.12.2009, 08:28 PM
[Kein Betreff] - von obamaimladen - 17.12.2009, 08:29 PM
RE: - von obamaimladen - 18.12.2009, 09:48 AM
RE: - von obamaimladen - 18.12.2009, 10:44 AM
[Kein Betreff] - von Rumgucker - 18.12.2009, 10:44 AM
[Kein Betreff] - von obamaimladen - 18.12.2009, 05:01 PM
[Kein Betreff] - von Rumgucker - 18.12.2009, 05:14 PM
[Kein Betreff] - von Rumgucker - 18.12.2009, 06:35 PM
RE: RE: - von audiosix - 18.12.2009, 08:40 PM
[Kein Betreff] - von Rumgucker - 19.12.2009, 11:20 AM
[Kein Betreff] - von audiosix - 19.12.2009, 11:48 AM
[Kein Betreff] - von Rumgucker - 19.12.2009, 11:50 AM
EF 86 - von audiosix - 19.12.2009, 12:16 PM
[Kein Betreff] - von obamaimladen - 19.12.2009, 12:17 PM
[Kein Betreff] - von Rumgucker - 19.12.2009, 12:19 PM
[Kein Betreff] - von obamaimladen - 19.12.2009, 12:23 PM
RE: - von Rumgucker - 19.12.2009, 12:25 PM
RE: - von obamaimladen - 19.12.2009, 12:26 PM
[Kein Betreff] - von Rumgucker - 19.12.2009, 12:31 PM
[Kein Betreff] - von Rumgucker - 19.12.2009, 12:35 PM
[Kein Betreff] - von Rumgucker - 19.12.2009, 12:39 PM
[Kein Betreff] - von obamaimladen - 19.12.2009, 12:48 PM
[Kein Betreff] - von Rumgucker - 19.12.2009, 12:51 PM
[Kein Betreff] - von Rumgucker - 19.12.2009, 02:59 PM
[Kein Betreff] - von Rumgucker - 19.12.2009, 05:46 PM
[Kein Betreff] - von obamaimladen - 19.12.2009, 07:44 PM
[Kein Betreff] - von Rumgucker - 19.12.2009, 07:52 PM
[Kein Betreff] - von kahlo - 19.12.2009, 08:32 PM
[Kein Betreff] - von Rumgucker - 19.12.2009, 08:37 PM
RE: - von Rumgucker - 19.12.2009, 08:39 PM
RE: RE: - von kahlo - 19.12.2009, 08:44 PM
[Kein Betreff] - von audiosix - 19.12.2009, 11:04 PM
[Kein Betreff] - von Gerd - 20.12.2009, 11:40 AM
[Kein Betreff] - von Rumgucker - 21.12.2009, 10:23 AM
[Kein Betreff] - von Rumgucker - 21.12.2009, 11:50 AM
[Kein Betreff] - von Rumgucker - 21.12.2009, 01:30 PM
[Kein Betreff] - von Rumgucker - 21.12.2009, 03:56 PM
[Kein Betreff] - von Rumgucker - 22.12.2009, 11:26 AM
[Kein Betreff] - von Rumgucker - 22.12.2009, 12:07 PM
RE: - von obamaimladen - 22.12.2009, 12:21 PM
[Kein Betreff] - von Rumgucker - 22.12.2009, 12:27 PM
[Kein Betreff] - von Rumgucker - 22.12.2009, 12:40 PM
RE: - von obamaimladen - 22.12.2009, 12:43 PM
[Kein Betreff] - von Rumgucker - 22.12.2009, 12:48 PM
[Kein Betreff] - von Rumgucker - 22.12.2009, 01:17 PM
[Kein Betreff] - von Rumgucker - 22.12.2009, 08:38 PM
[Kein Betreff] - von Rumgucker - 23.12.2009, 01:04 PM
[Kein Betreff] - von Rumgucker - 23.12.2009, 01:20 PM
[Kein Betreff] - von Rumgucker - 23.12.2009, 01:50 PM
[Kein Betreff] - von Rumgucker - 23.12.2009, 01:51 PM
[Kein Betreff] - von Rumgucker - 23.12.2009, 02:05 PM
[Kein Betreff] - von Rumgucker - 23.12.2009, 02:14 PM
[Kein Betreff] - von Rumgucker - 23.12.2009, 02:56 PM
[Kein Betreff] - von Rumgucker - 23.12.2009, 03:11 PM
[Kein Betreff] - von Rumgucker - 23.12.2009, 03:23 PM
[Kein Betreff] - von kahlo - 23.12.2009, 06:13 PM
[Kein Betreff] - von Gerd - 23.12.2009, 06:24 PM
[Kein Betreff] - von Rumgucker - 23.12.2009, 06:36 PM
[Kein Betreff] - von Rumgucker - 25.12.2009, 03:20 PM
[Kein Betreff] - von audiosix - 26.12.2009, 10:00 AM
RE: - von rumlungerer - 27.12.2009, 11:41 AM
RE: - von obamaimladen - 27.12.2009, 01:46 PM
[Kein Betreff] - von audiosix - 27.12.2009, 08:32 PM
RE: RE: - von Rumgucker - 28.12.2009, 09:48 AM
[Kein Betreff] - von Rumgucker - 28.12.2009, 10:50 AM
RE: - von rumlungerer - 28.12.2009, 07:19 PM
[Kein Betreff] - von Rumgucker - 28.12.2009, 07:37 PM
[Kein Betreff] - von Rumgucker - 29.12.2009, 12:17 PM
[Kein Betreff] - von Rumgucker - 29.12.2009, 12:48 PM
[Kein Betreff] - von Rumgucker - 29.12.2009, 01:13 PM
[Kein Betreff] - von Rumgucker - 29.12.2009, 01:40 PM
[Kein Betreff] - von Rumgucker - 29.12.2009, 01:49 PM
[Kein Betreff] - von Rumgucker - 29.12.2009, 02:44 PM
[Kein Betreff] - von Hans Dorn - 29.12.2009, 02:46 PM
[Kein Betreff] - von Rumgucker - 29.12.2009, 03:02 PM
[Kein Betreff] - von Rumgucker - 29.12.2009, 03:10 PM
[Kein Betreff] - von Rumgucker - 29.12.2009, 03:14 PM
RE: - von Gerd - 29.12.2009, 03:41 PM
[Kein Betreff] - von Rumgucker - 29.12.2009, 04:47 PM
[Kein Betreff] - von Hans Dorn - 29.12.2009, 05:43 PM
[Kein Betreff] - von Rumgucker - 29.12.2009, 06:14 PM
[Kein Betreff] - von Hans Dorn - 29.12.2009, 06:50 PM
[Kein Betreff] - von Rumgucker - 29.12.2009, 07:03 PM
RE: - von Gerd - 29.12.2009, 07:07 PM
[Kein Betreff] - von Rumgucker - 29.12.2009, 07:30 PM
[Kein Betreff] - von Gerd - 29.12.2009, 09:22 PM
RE: - von rumlungerer - 29.12.2009, 11:56 PM
[Kein Betreff] - von Rumgucker - 30.12.2009, 09:43 AM
[Kein Betreff] - von rumlungerer - 30.12.2009, 09:54 AM
RE: - von Hans Dorn - 30.12.2009, 09:57 AM
[Kein Betreff] - von Rumgucker - 30.12.2009, 10:03 AM
[Kein Betreff] - von obamaimladen - 30.12.2009, 12:07 PM
[Kein Betreff] - von Rumgucker - 30.12.2009, 09:01 PM
[Kein Betreff] - von rumlungerer - 31.12.2009, 12:36 AM
[Kein Betreff] - von Rumgucker - 31.12.2009, 11:03 AM
RE: - von rumlungerer - 31.12.2009, 04:04 PM
[Kein Betreff] - von Rumgucker - 31.12.2009, 04:08 PM
[Kein Betreff] - von Hans Dorn - 31.12.2009, 04:13 PM
[Kein Betreff] - von rumlungerer - 02.01.2010, 04:18 PM
[Kein Betreff] - von Rumgucker - 02.01.2010, 04:35 PM
RE: - von Gerd - 02.01.2010, 07:59 PM
[Kein Betreff] - von Rumgucker - 03.01.2010, 11:30 AM
RE: - von obamaimladen - 03.01.2010, 02:39 PM
RE: - von Gerd - 03.01.2010, 10:45 PM
[Kein Betreff] - von Rumgucker - 03.01.2010, 10:57 PM
RE: - von Gerd - 04.01.2010, 08:24 AM
RE: RE: - von obamaimladen - 04.01.2010, 11:18 AM
[Kein Betreff] - von Rumgucker - 04.01.2010, 11:20 AM
RE: - von obamaimladen - 04.01.2010, 11:23 AM
RE: - von Gerd - 04.01.2010, 11:39 AM
RE: RE: RE: - von Gerd - 04.01.2010, 11:40 AM
[Kein Betreff] - von Hans Dorn - 06.01.2010, 04:03 AM
[Kein Betreff] - von Rumgucker - 06.01.2010, 10:03 AM
[Kein Betreff] - von Hans Dorn - 06.01.2010, 05:28 PM
[Kein Betreff] - von Rumgucker - 06.01.2010, 06:17 PM
RE: - von Hans Dorn - 06.01.2010, 10:03 PM
[Kein Betreff] - von rumlungerer - 12.03.2010, 10:03 PM
[Kein Betreff] - von Hans Dorn - 12.03.2010, 10:24 PM
RE: - von diabolos - 12.03.2010, 11:20 PM
[Kein Betreff] - von Rumgucker - 14.03.2010, 11:36 AM
[Kein Betreff] - von Hans Dorn - 14.03.2010, 05:00 PM
RE: - von Rumgucker - 14.03.2010, 06:00 PM
