21.02.2009, 04:12 PM
HI
Also ich hab mir jetst 2 Dateien erstellt und zwar.
irf540N.asy
Version 4
SymbolType BLOCK
LINE Normal -16 -24 -16 -39
LINE Normal -16 8 -16 -9
LINE Normal -16 41 -16 24
LINE Normal -1 33 -16 33
LINE Normal -1 0 -1 33
LINE Normal -16 0 -1 0
LINE Normal 0 -32 -16 -32
LINE Normal -27 -32 -27 32
LINE Normal 0 -63 0 -32
LINE Normal -1 65 -1 33
LINE Normal -63 32 -27 32
TEXT 20 -40 VRight 0 IRF540N
SYMATTR Prefix x
SYMATTR Value IRF540N
SYMATTR ModelFile irf540N.cir
PIN 0 -64 NONE 8
PINATTR PinName 1
PINATTR SpiceOrder 1
PIN -64 32 NONE 8
PINATTR PinName 2
PINATTR SpiceOrder 2
PIN 0 64 NONE 8
PINATTR PinName 3
PINATTR SpiceOrder 3
Die scheint auch zu Funktionieren und als 2tes habe ich eine Datei mit dem Namen.
irf540N.cir erstellt.
.SUBCKT irf540n 1 2 3
* SPICE3 MODEL WITH THERMAL RC NETWORK
* Model Generated by MODPEX *
*Copyright© Symmetry Design Systems*
* All Rights Reserved *
* UNPUBLISHED LICENSED SOFTWARE *
* Contains Proprietary Information *
* Which is The Property of *
* SYMMETRY OR ITS LICENSORS *
*Commercial Use or Resale Restricted *
* by Symmetry License Agreement *
* Model generated on Sep 5, 01
* MODEL FORMAT: SPICE3
* Symmetry POWER MOS Model (Version 1.0)
* External Node Designations
* Node 1 -> Drain
* Node 2 -> Gate
* Node 3 -> Source
M1 9 7 8 8 MM L=100u W=100u
.MODEL MM NMOS LEVEL=1 IS=1e-32
+VTO=3.58173 LAMBDA=0.00806114 KP=112.25
+CGSO=1.896e-05 CGDO=1e-11
RS 8 3 0.025918
D1 3 1 MD
.MODEL MD D IS=1.565e-11 RS=0.006486 N=1.1328 BV=100
+IBV=0.00025 EG=1.2 XTI=3.32496 TT=0
+CJO=1.16e-09 VJ=3.16363 M=0.840542 FC=0.5
RDS 3 1 1e+06
RD 9 1 0.0130608
RG 2 7 6.45271
D2 4 5 MD1
* Default values used in MD1:
* RS=0 EG=1.11 XTI=3.0 TT=0
* BV=infinite IBV=1mA
.MODEL MD1 D IS=1e-32 N=50
+CJO=1.30485e-09 VJ=0.899032 M=0.9 FC=1e-08
D3 0 5 MD2
* Default values used in MD2:
* EG=1.11 XTI=3.0 TT=0 CJO=0
.MODEL MD2 D IS=1e-10 N=0.4 RS=3e-06
RL 5 10 1
FI2 7 9 VFI2 -1
VFI2 4 0 0
EV16 10 0 9 7 1
CAP 11 10 2.35428e-09
FI1 7 9 VFI1 -1
VFI1 11 6 0
RCAP 6 10 1
D4 0 6 MD3
* Default values used in MD3:
* RS=0 BV=infinite IBV=1mA
.MODEL MD3 D IS=1e-10 N=0.4
.ENDS irf540n
*SPICE Thermal Model Subcircuit
.SUBCKT irf540nt 3 0
R_RTHERM1 2 3 0.158
R_RTHERM2 1 2 0.274
R_RTHERM3 0 1 0.29
C_CTHERM1 2 3 0.00131
C_CTHERM2 1 2 0.001686
C_CTHERM3 0 1 0.022562
.ENDS irf540nt
Diese Datei habe ich nun eingefügt jedoch sagt mir das Programm
Could not open library file "irf540N.cir"
irf540N.asy
Version 4
SymbolType BLOCK
SYMATTR Prefix x
PIN 0 -64 NONE 8
PINATTR PinName 1
PIN -64 32 NONE 8
PINATTR PinName 2
PIN 0 64 NONE 8
PINATTR PinName 3
* Node 1 -> Drain
* Node 2 -> Gate
* Node 3 -> Source
RS 8 3 0.025918
D1 3 1 MD
RDS 3 1 1e+06
RD 9 1 0.0130608
RG 2 7 6.45271
D2 4 5 MD1
D3 0 5 MD2
RL 5 10 1
FI2 7 9 VFI2 -1
VFI2 4 0 0
EV16 10 0 9 7 1
FI1 7 9 VFI1 -1
VFI1 11 6 0
RCAP 6 10 1
D4 0 6 MD3
.ENDS irf540n
R_RTHERM1 2 3 0.158
R_RTHERM2 1 2 0.274
R_RTHERM3 0 1 0.29
.ENDS irf540nt
