22.07.2008, 01:54 PM
Auch ganz nett...vielleicht etwas hoch für Neubau, aber in mein Wohnzimmer würde es passen
[Bild: rubic2.jpg]
Also worth noting in the pic of the horns positioned horizontally is that each cab measures 2.4 meters wide x 1.2 meters deep x 600 mm high. So 3 cabs would be 1.8 meters high and guess what, I'm 1.81 meters tall, so you're good Mircea, but not that good, ha ha.
[Bild: rubicspl.jpg]
Its ok standing within 3 meters untill a frequency above 60Hz comes in, then it hurts. It feels like when you accidentally hit your head on something really hard and it kind of phases you out for about 3 seconds. But its like that happening all the time so you just have to move away, or should I say stagger away as its like being in a fight with Tyson when those upper bass notes start playing. Other than being attacked above 60Hz, below 60 is very comfortable. Tracks with 25 to 30Hz just move you back and fourth in time with the oscillations.
[Bild: rubicplot.jpg]
In band max continuous output is 145dB with peaks of 151dB at 1 meter. Output readings measured with 6000 watts input, which is 1500 watts to each driver.
http://www.speakerplans.com/forum/forum_...14904&PN=1
[Bild: rubic2.jpg]
