16.02.2008, 03:45 PM
		Naja bei dem Sony SRX-S110 kosten die Ersatzlampen (!!, zwei !) schon locker >6k? ...
Zum Beamer selbst gibts kaum auskunft...da redet man nicht mehr drüber...
BTW:
Ersatzlinsen >17k$
Ehem, ja Preis auf Anfrage....machts einer ?
Aber die Daten von dem Teil sind schon beeindruckend....
110kg Gewicht....1,33m lang...bis zu 5,4kW Energiebedarf
http://www.projector-discount.de/product...-S110.html
Ohje...das ist nicht meine Welt....Sony Ersatzlampe VPD LE100 knapp 18k? ... Hallo ??? was ist an einer Xenon Lampe soooo schweine Teuer ???
Bin verwirrt....
2.Versuch :
Einen Anhaltspunkt gibts hier :
http://www.pcworld.com/article/id,136346...ticle.html
"Projecting Power
Let's just make this clear: The last thing you use this projector for is a PowerPoint presentation, unless you have some really big pie charts. That's because the Sony SRXS110 has a display resolution of 4096 by 2160 pixels (otherwise known as 4K resolution). You can display four high-definition images together and still have a few hundred thousand pixels left over. The SRXS110 is designed for digital cinema projection, but it's actually a bit overqualified. Its top projection rate is 60 frames per second (compared with film's 24 fps), and few films are actually shot and distributed in 4K. It handily " up-rezzes" lower-quality images, though, so even your DVD collection will look pretty hot. The cost? Between $70,000 and $100,000--steep, but the expensive model also automatically pops popcorn."
BTW:
Ersatzlinsen >17k$
Bin verwirrt....
2.Versuch :
"Projecting Power
