28.09.2012, 07:18 PM
Eine wirklich einfache Angelegenheit!
Schaltstabi ganz simpel
Eine wirklich einfache Angelegenheit!![]()
Ist es malwieder soweit![]()
Zitat:When the output voltage is greater than approximately 6V,
and the duty cycle at minimum input voltage is greater than
approximately 50%, the designer should exercise caution in
selection of the output filter components. When an application
designed to these specific operating conditions is subjected
to a current limit fault condition, it may be possible to observe
a large hysteresis in the current limit. This can affect the output
voltage of the device until the load current is reduced
sufficiently to allow the current limit protection circuit to reset
itself.
Under current limiting conditions, the LM267x is designed to
respond in the following manner:
1. At the moment when the inductor current reaches the
current limit threshold, the ON-pulse is immediately
terminated. This happens for any application condition.
2. However, the current limit block is also designed to
momentarily reduce the duty cycle to below 50% to avoid
subharmonic oscillations, which could cause the inductor
to saturate.
3. Thereafter, once the inductor current falls below the
current limit threshold, there is a small relaxation time
during which the duty cycle progressively rises back
above 50% to the value required to achieve regulation.
![[Bild: 1803_555REG.jpg]](https://stromrichter.org/d-amp/content/images/1803_555REG.jpg)
![[Bild: 1_updown5.png]](https://stromrichter.org/d-amp/content/images/1_updown5.png)
Ja richtig, man könnte R1 einstellbar
machen- habe ich übersehen, sorry-
aber z.B. Werte um 1 Ohm ( mit feiner Abstufung )
sind kaum zu bekommen und ein Poti für
diesen Bereich und der erforderlichen
Leistung noch weniger.
Hab in blinderweise überall nur Festwiderstände
gesehen.
Zitat:Original geschrieben von ursAngesichts dieses. R1-Desasters spreche ich Dir die Qualifikation ab, die Schaltung beurteilen zu können, urs....
Allerdings- im Prinzip eine sehr elegante Lösung !!!
Versuche gerade irgendwie ohne Ladedrossel auszukommen
( habe keine )..
Nein, das Wickeln ist kein Problem
für mich -aber das Ausmessen von µH.
Der Sourcewiderstand von 1 Ohm begrenzt
die Leistungsfähigkeit bei 12 Volt
Akkuspannung sehr deutlich und ein NE 555
oder ICM 755 verträgt keine 24 V direkt,
so dass dann doch einige zusätzliche
Bauteile anfallen werden.
Zitat:Original geschrieben von ursNur um das mal zu entkräften: Ich habe diese Schaltung aufgebaut und erprobt bis 350V/30mA. Ab 300V/30mA braucht ein IRF740 einen Kühlkörper. Eingangsspannung 9..16V.
Aber bei einem Tastverhältnis von z.B. 85 %
vermute ich eine erreichbare Ausgangsspannung,
die nur ca. 6 x höher als die Eingangsspannung ist.
Das ist für eine Anodenspannung zu wenig.
![[Bild: 376_NE555_Stepup_1.gif]](https://stromrichter.org/d-amp/content/images/376_NE555_Stepup_1.gif)
