10.11.2011, 09:45 PM
		Hallo,
hat jemand von euch ein funktionierendes Röhrenmodell von der EF184 für Ltspice?
Im Netz habe ich nur dieses hier gefunden:
*Vacuum Tube pentode aka ef184 (assumes K tied to g3)
.SUBCKT X6EJ7 A S G K
* Calculate contribution to cathode current
*the number at the right end determines sharpness of knee
Bat at 0 V=0.636*ATAN(V(A,K)/32)
*the URAMP(V(S,K)/# mostly determines peak plate current, grid line spacing nearly constant
*the number at the right end determines slope of grid lines (plate resistance)
Bgs gs 0 V=URAMP(V(S,K)/42.8+V(G,K)*1.55+V(A,K)/9000)
*the exponent sets the linearity of grid line spacing, and big impact on peak plate currrent
Bgs2 gs2 0 V=V(gs)^1.5
Bcath cc 0 V=V(gs2)*V(at)
* Calculate anode current, grid line spacing adjust and peak plate current
Ba A K I=7.985E-3*V(cc)
* Calculate screen current
Bscrn sc 0 V=V(gs2)*(1.1-V(at))
Bs S K I=0.20E-2*V(sc)
* Grid current (approximation - does not model low va/vs)
Bg G K I=(URAMP(V(G,K)+1)^1.5)*50E-6
* Capacitances
Cg1 G K 10p
Cak A K 3p
Cg1a G A 0.0055p
.ENDS X6EJ7
Leider funktioniert das Modell nicht
Danke!
Grüße
bambam
* Capacitances
Cg1 G K 10p
Cak A K 3p
Cg1a G A 0.0055p
.ENDS X6EJ7
 Danke!
Grüße
bambam
 ? *.asc und Modelldatei, so wie du es benutzt?
 ![[Bild: 1_bambam1.png]](https://stromrichter.org/d-amp/content/images/1_bambam1.png)
