Hm, was gibt es da nicht zu verstehen?
Das R2R-Netzwerk ist mit 0,01% Widerständen wirklich genau nur für DC.
Oder sind alle parasitären Kapazitäten auch auf 0,01% "gemachted"?
Und davon abgesehen sehe ich in der Ladungsinjektion der Analogschalter das größte Problem.
Übrigens muß die Versorgungsspannung dieses DAC dann auch für 24bit gut sein - so viele Fragen...
Themen: 354
Da kommen interessante Antworten.
Zitat: Quote: Originally Posted by doctormord View Post I mean compensation of capacitive resistance caused by stray capacitance. When I.e. switching at 3Mhz and 1pf stray capacitance this will render to 50kOhm capacitive resistance. This must be compensated somehow, otherwise the voltages at the netpoints aren't right.
Zitat:No problem here, thanks to the very clean and compact SMT design and 4 layer PCB, any stray capacitance are too low to matter much. I even choose to use only 7 bit from each shift register, as the 8th bit are located on the other side of the chip... And the 470 pF capacitor at the output of the R-2R resistor chain take care of anything coming though. The results can be seen at the FFT plots, so clean....
Zitat: Originally Posted by soekris View Post No problem here, thanks to the very clean and compact SMT design and 4 layer PCB, any stray capacitance are too low to matter much.
Zitat:How low is your stray capacitance between your traces? In my old I/V DAC design some x pF have mattered. Also take care after time, where some dirt comes over/between the soldering SMD's..
Zitat:Haven't calculated trace stray capacitance, just did my best to keep things separated at layout and have the analog signals on the top side, with digital signals to the shift registers on the bottom side. Again, the advantage of the sign magnitude R-2R dac is that MSB bits are NOT switching when not used, so you don't have large signals straying into low levels analog signals. That's also why you don't need de-glitching on a sign magnitude DAC, there simply aren't any glitches.... Those "spurious power harmonics" are more than -140 db down and mostly likely from the EMU-0404, as my initial testing are powered from my lab power supply.... I also really need better test equipment, the choice seems to be between real audio analyzers starting at $10K, or inadequate low cost AD/DA boxes like the EMU-0404. Something in between are needed, that might be my next project
Gleich auf "tagesschau24"
Der Arbeitsmarktreport - das Märchen vom Fachkräftemangel
Doku
Wdh. vom 22.7.
'Ingenieursmangel! Ärztemangel! Zu wenig IT-Spezialisten!' und 'Wenn wir nicht gegensteuern, geht es bergab mit Deutschland.' Das sind alltägliche Schlagzeilen, mit denen Politik gemacht wird. 'Der Arbeitsmarktreport' deckt die Hintergründe des seit Jahrzehnten beklagten Fachkräftemangels auf. Tatsächlich lenkt der lautstarke Hilferuf bewusst ab von gewichtigen Problemen: Lohndumping und Arbeitslosigkeit. Akteure in diesem Spiel sind Lobbyverbände der Wirtschaft, die zusammen mit den Politikern und der Bundesagentur für Arbeit den Arbeitskräftemarkt in Deutschland gestalten.
Kaum ein Lobbyverband hat sich so vehement dafür eingesetzt, ausländische Fachkräfte ins Land zu holen, wie der Verein Deutscher Ingenieure (VDI).
Ingenieure selbst sind es, die dem Verein vorwerfen, er lasse sich von Unternehmen instrumentalisieren und drücke das Mindestgehalt. Weil der Ingenieursverband regelmäßig mit Horror-Zahlen aufwartet, hat man den Ingenieursberuf zum Mangelberuf erster Klasse erklärt und erlaubt Unternehmen jetzt, hochqualifizierte ausländische Fachkräfte einzustellen, zu einem Mindestlohn von 32.500 Euro im Jahr. Früher lag diese Grenze bei 66.000 Euro.
Mit Blue Card und europäischer Freizügigkeit sollen Fachkräfte aus Spanien, Griechenland, Rumänien und Bulgarien auf den deutschen Arbeitsmarkt strömen. Deutschland ist stolz darauf, Krisenstaaten zu unterstützen, indem es ihnen Arbeitslose abnimmt.
Offene Stellen ohne Bewerber? Tatsächlich kommen derzeit sechs passende Bewerber auf ein Jobangebot. Provozieren Unternehmer also ein bewusst Überangebot an Fachkräften, um trotz anziehender Konjunktur geringere Löhne zahlen zu können? Die Bewerber von heute sehen sich nicht mehr als Bittsteller.
Sie fordern, anstatt schlechte Bedingungen zu akzeptieren, nur um einen Job zu bekommen. Am Ende entpuppt sich der behauptete Fachkräftemangel als Strategie, die sich für Politik und Wirtschaft durchaus lohnen kann. (Senderinfo)
> 21.00 | 45 Min. "
Themen: 354
Das würde man sofort sehen, wenn er mal einen F-Gang des Wandlers von 0Hz bis 384 kHz aufnimmt.
Na da werde ich mal nachhaken.
Themen: 354
Themen: 354
Schöner Volumenknopp.
Und diese russischen Koppel-Cs..
Diese Kabelbindertrafos habe ich jetzt schon des Öfteren gesehen.
Davon abgesehen ist die Betriebssicherheit doch zweifelhaft.
2*L15D+Connexelectronic SMPS800RE. Supply voltage +/-58 v
Quelle:
http://www.diyaudio.com/forums/class-d/8...ost4001698
Ja, sind DIY-LLC-Trafos. An die "richtigen" Spulenkörper kommt man kaum ran.
Themen: 354
Bezüglich des DACs, da kommt jetzt die "KIMI RÄIKKÖNEN" Variante. (Leave me alone, I know what I'm doing)
Zitat: Originally Posted by doctormord View Post Well, every single resistor got its own parasitic capacity, no matter how the layout is routed. (Even soldering joints are relevant) Beside this, your switching is done via MOSFETs? Those gates are capacitiv coupled via the bulk, so there are more than a few pF. Clean plots? Easy explanation. At 384kHz the 470pF capacitors have a capacitive resistance of ~880Ohms, so 384kHz wont be possible with full output signal scale. (Would guess, even 20kHz will be damped) Conversation error induced harmonics are just shorted this way. A 384kHz frequency plot would show this.
Zitat:The switching by the mosfets inside the LVC595's is not an issue driving the resistors, more a power supply decoupling issue.... And of course the resistors have parasitic capacitance, like between any two signals, but those are sub pF. Lets just say I'm not worried about the parasitic capacitances anywhere in my DAC design. Although I'm not a RF designer, I design Ghz computer boards in my day job so I have some experience there.... 384 Khz sampling is more for show anyway, afaik there are no 384 Khz music files available, I could as well do 768 Khz sampling.... I have have one more analog bessel low pass filter in the output drivers, have decided on a system -3db at 200 Khz, 12 db per octave passive filter, which in my opinion is perfectly fine, there isn't any music up there.... But feel free to remove those capacitors
Du bist die lästige Fliege in seinem Thread...
Themen: 354
I know..
Trotzdem erstaunlich, wieviele Leute das kaufen wollen/würden.
Zugegeben, ist schon ein "bischen advanced".
Themen: 354
Fehlt eigentlich noch ein Weissblechgehäuse, so aus dem Bauch heraus würde ich vermuten, dass das Teil ein "ordentlicher" Sender ist.
Auch finde ich, dass der Taktgenerator recht weit vom FPGA entfernt ist, und, für mich elementar, er sitzt direkt neben der Heizung. (LDO)
Ne. Die Spannungshübe und Ströme sind gering, die "Antennenlängen" kurz und die Parasiten fressen auch noch viel weg.
Zu dem Monster DAC - ich sehe da die Motivation in dieser typischen Zahlenverliebtheit: 24bit sind natürlich besser als 16bit und 32bit sind natürlich besser als 24bit usw - läßt sich beliebig fortsetzen.
Unsliebsame Einwände, wie die Fehler durch charge-injection, werden schlichtweg weggebügelt - ansonsten müßte man ja vlt zugeben, dass bei höheren Abtastraten gegenüber schnöden 16bit-Systemen überhaupt nichts zu gewinnen ist.
