28.11.2014, 12:02 PM
Netzteile sind ja ganz klar deine Domäne.
"The Stage is yours!
TPA3132D2 50+50W Miniatur.
Zitat:The following update was also made to the TPA3111D1:
On Page 14, the Application Information schematic now includes a 1uF cap on the AVCC terminal (terminal 7). This capacitor is optional and is recommended for audio conditions where better PSRR in the audio band is desired. It is not necessary for proper operation of the IC. This capacitor was inadvertently left off the Application Information schematic when the data sheet was originally published.
"The Stage is yours!![]()
![[Bild: 94_tpa3132d2_top.png]](https://stromrichter.org/d-amp/images/forumuploadpics/94_tpa3132d2_top.png)
![[Bild: 142_tpa3132d2_bot.png]](https://stromrichter.org/d-amp/images/forumuploadpics/142_tpa3132d2_bot.png)
![[Bild: 91_tpa3132d2_top_cop.png]](https://stromrichter.org/d-amp/images/forumuploadpics/91_tpa3132d2_top_cop.png)
![[Bild: 195_tpa3132d2_bot_cop.png]](https://stromrichter.org/d-amp/images/forumuploadpics/195_tpa3132d2_bot_cop.png)
![[Bild: 170_tpa3132d2_top.png]](https://stromrichter.org/d-amp/images/forumuploadpics/170_tpa3132d2_top.png)
![[Bild: 185_tpa3132d2_bot.png]](https://stromrichter.org/d-amp/images/forumuploadpics/185_tpa3132d2_bot.png)
![[Bild: 158_tpa3132d2_top_cop.png]](https://stromrichter.org/d-amp/images/forumuploadpics/158_tpa3132d2_top_cop.png)
![[Bild: 138_TPA_right.png]](https://stromrichter.org/d-amp/images/forumuploadpics/138_TPA_right.png)
![[Bild: 123_TPA_wrong.png]](https://stromrichter.org/d-amp/images/forumuploadpics/123_TPA_wrong.png)
![[Bild: 51_TPA3132D2_0C_bot.png]](https://stromrichter.org/d-amp/images/forumuploadpics/51_TPA3132D2_0C_bot.png)
Meine Frage nach dem dort verbauten Poti-Typ hast Du noch nicht beantwortet.
