Ein schönes Bekenntnis zu stabilen Lautsprechermembranen findet man bei Harbeth - die schließlich eine große Tradition mit Polypropylen und Bextrene - Membranen haben. Finde ich sehr ehrlich von denen!
Zitat:
http://www.harbeth.co.uk/uk/index.php?se...recentnews
Inadequacies of 'industry standard' speaker cones
03.11.2014
It is little wonder that loudspeakers with mere polypropylene cones can’t match the open and dynamic sound of a Harbeth RADIAL
drive unit. As a new video on the Harbeth User Group clearly shows, shampoo-bottle plastics just don’t have enough rigidity. Cone video
Stiffness is a key attribute for a loudspeaker cone if it is to produce a good sound, yet as the new video demonstrates, most cones are pretty feeble.
While even the smallest (110mm) RADIAL
cone will easily withstand the weight of a house brick (see above), a similar size polypropylene cone simply buckles and is squashed to destruction.
“The Harbeth cone even withstood the weight of a hefty 4.9kg steel billet”, explains Harbeth’s MD and designer Alan Shaw.
“It’s no accident that the super-clear Harbeth sound is the product of our wonderfully rigid cones. You can think of Harbeth RADIAL
technology as a reinforced plastic which solves numerous engineering challenges. Unless cones behave in a pistonic way across the entire audio range, as RADIAL
ones do , it’s impossible to achieve a really natural sound. “
A ten minute audition at your local dealer will reveal all the strengths of the Harbeth drive-unit technology!
- ein wenig unverfroren finde ich dann schon die Aufforderung gehörmässig die neue Membrantechnologie überprüfen zu wollen.
- schmunzeln lässt mich der Test mit den Gewichten auf den Membranen, denn dass erinnert an Leak Sandwich Lautsprecher aus den 60er Jahren.....
Gruß, Dragan
