8-64 Bit... was das Herz begehrt.
PTC - PT6306
PT6306 is a 64-Bit High-Voltage Display Driver utilizing CMOS Technology specially designed for VFD display panels.
It provides 64-bit bidirectional shift register, 64-bit latch and high-voltage CMOS driver. The logic circuit operates on 5V power supply (CMOS Level Input) making it possible for PT6306 to be used in conjunction with a microcomputer. The driver block consists of 80V, 50 mA (max.) high voltage output buffer. Pin assignments and application circuits are optimized for easy PCB Layout and cost saving benefits.
Features
CMOS Technology
Low Power Consumption
64-Bit Bidirectional shift registers.
Data Controlles via External Transfer Clock and Latch
High Speed Data Transfer (fmax=25MHz, Min.: 16 MHz in cascade connection)
Wide Operating temperature Range: -40 to +85°C
High Voltage Output (80V, 50 mA max.)
Polarities of all Drivers may be inverted by using PCB Pin
Available in COB and 100-pin QFP
http://www.kamaka.de/index.php?option=co...&Itemid=83
