30.04.2011, 10:06 AM
Wenn man meine Schaltung mit Germanium-BJT bestücken würde...
Begrenzer mit OTA
! Wo hast denn das ausgebuddelt
.model AC128_X PNP(IS=1.41f ISC=0 ISE=0 IKF=80m IKR=0 ITF=0.4 +NC=2 NE=1.5 BF=70 BR=4.977 RB=10 RC=2.5 CJC=9.728p CJE=8.063p +TR=33.42n TF=179.3p FC=0.5 EG=1.11 VJC=0.2 VJE=0.2 VTF=4 +MJC=0.5776 MJE=0.3677 XTB=1.5 XTF=6 XTI=3)
.model AC127_X NPN(IS=1.41f ISC=0 ISE=0 IKF=80m IKR=0 ITF=0.4 +NC=2 NE=1.5 BF=70 BR=4.977 RB=10 RC=2.5 CJC=9.728p CJE=8.063p +TR=33.42n TF=179.3p FC=0.5 EG=1.11 VJC=0.2 VJE=0.2 VTF=4 +MJC=0.5776 MJE=0.3677 XTB=1.5 XTF=6 XTI=3)
Zitat:These models are quite bad!Deckt sich mit meiner Ansicht...
Vbe is around 0.7V, a common emitter amplifier with about 50dB gain has an upper frequency of about 7MHz! That is nothing like using those old germanium transistors with an Ft of 1.5MHz!
If you plug in 2N3906, a jelly bean type Si PNP transistor, you get similar results.
Looks like someone just renamed a simple Si transistor model!
Peter
![[Bild: 800_dpairdiodes200mv.png]](https://stromrichter.org/d-amp/content/images/800_dpairdiodes200mv.png)
![[Bild: 800_diffpairdiodes10v.png]](https://stromrichter.org/d-amp/content/images/800_diffpairdiodes10v.png)
Zitat:Original geschrieben von voltwideSind das die neuen binären .asc Dateien
Neues aus dem OTArium
https://stromrichter.org/d-amp/content/i...ipper1.asc
