PBG12201 Plasma Bargraph Display - reloaded
(01.08.2025, 09:31 AM)kahlo schrieb: Hi Richard,
The current through the display is limited by the resistors R7, R8, R17, R18. These resistors need to be able to handle some heat. They should be rated at least with 2W, better 5W. Please have a look to the photo below - the big light green Resistors are 5W-Pieces:
[Bild: attachment.php?aid=755]
The 33k resistor (R2) needs to be rated 1W. I have here two 0.6W resistors in parallel.
Hello and thank you very much for your helpful reply - I shall re-work my board to accommodate larger pieces - certainly larger than the 0805 parts I used!!!!
- Richard
Hello, I finally got the 5W resistors and a Zener rated at 2W. Now whilst the zener diode remains cool, the 5W resistor still gets too warm to touch. Is that what i should expect?
I have attached my schematic for comment if you can but I cannot see that I have deviated too far from the published design, I just made it for 5 phases. The design 'works' but I am uncomfortable with the generation of that much heat on something that should (I believe) consume very little current.
I would be grateful for any insight you may be able to provide.
- Richard
Angehängte Dateien
.pdf   Schematic_BarGraph2_2025-09-09.pdf (Größe: 107,12 KB / Downloads: 187)
Your schematic looks good.
Th NCH6300HV delivers 230V max. Assuming this number, some calculations:
R8 33k: U=230-68=162V | I=162/33000=0.0049A | P=0.8W
R15 36k display OFF: I=230/(36000+24000)=0.00383A | U=36000*0.00383=138V | P=0.53W
R15 36k display ON: U=230-70(assumed glow voltage)=160V | I=160/36000=0.00444A |  P=0.71W
If your resistors have to handle this without help of something like a copper area or heat sink, they dissipate the energy by heating up. This is fine, as long as they are specified correctly and the temperature remains far below the melting point of the solder  klappe .
(09.09.2025, 05:04 PM)kahlo schrieb: Your schematic looks good.
Hello and many thanks for your speedy reply.
I have tweaked the NCH6300HV to deliver the required 245V (with the assistance of Yan from Omnixie) so I re-calculate:
R8 33k: U=245-68=177V | I=177/33000=0.0053A | P=0.949W
R15 36k display OFF: I=245/(36000+24000)=0.00408A | U=36000*0.00408=147V | P=0.59W
R15 36k display ON: U=245-70(assumed glow voltage)=175V | I=175/36000=0.00486A |  P=0.85W
It just seems all a bit archaic making up all that heat just to generate 68V and I wonder if it might not be more efficient to add a simple 68V boost converter, even as something as simple as the NE555 based circuit - or an MC34063ased design. No, wait, I'm just looking at this https://ww1.microchip.com/downloads/aemD...05399B.pdf
Simple Voltage Regulator ....
What do you think?
 - Richard
(10.09.2025, 04:56 PM)scalesr1 schrieb: It just seems all a bit archaic making up all that heat just to generate 68V and I wonder if it might not be more efficient to add a simple 68V boost converter, even as something as simple as the NE555 based circuit - or an MC34063ased design. No, wait, I'm just looking at this https://ww1.microchip.com/downloads/aemD...05399B.pdf
What do you think?
 - Richard
You have the choice: archaic and simple (resistor + zener diode) or more parts for a boost converter. NE555 is not bad for that. The MC34063 would be a terrible choice...
The "Simple Voltage Regulator" from your datasheet link is a linear regulator which will produce the same amount of heat as the archaic solution.
An Update!
I sourced some of the LR8 regulators and tested it in circuit - no thing got warm and the thing still works!
I turned my attention to the 24K+36K combination to set the anode voltage - plenty of warmth here!
I am using 5W parts and whilst not too hot to touch I still worry about the heat. I just dont like making things hot.
Perhaps I should try replacing the single 24K/36K with two 48K/72K parts in parallel - just to get that temperature down - or shouldn't I worry so much?
- Richard
