14.09.2020, 04:11 PM
		aha.
https://www.soundphilereview.com/news/pu...inux-1200/
versuche ich mal... (wenn V 11+ drauf ist )
Zitat:It is possible to disable resampling by simply adding the avoid-resampling = yes line in the /etc/pulse/daemon.conf file if you have PulseAudio 11.0 installed. You can then check the sample rate being used by issuing the command pacmd list-sinks in a terminal (you will see a line similar to sample spec: s32le ch 2 44100 Hz, which will give you information on sample rate).
