#32
Hab hier die Manual vom Music Manager, kann sie aber nicht hochladen
zum Einfügen habe ich folgendes gefunden
7. Suggested Tuning Procedure Supporting Different Sample Rates
Since the resulting tuning is stored in a single parameter list that is downloaded to PS Keys and can be stored in a user defined .psr file, CSR recommends the following procedure to ensure the parameter data is correctly stored and downloaded.
1. Connect a source, play the music or test file at the 44.1kHz sample rate.
2. Make all the required Music Manager adjustments for 44.1kHz in monitoring mode.
When the adjustments are complete:
2.1. Click Download Params.
2.2. Enter a suitable name for the file.
2.3. Click Save PSR File while still in monitoring mode.
The saved .psr file contains only 44.1kHz results.
3. Stop music play, re-connect the source, play the music or test file at 48kHz sample rate.
4. Make all the required Music Manager adjustments for 48kHz in monitoring mode. When the adjustments are complete:
4.1. Click Download Params.
4.2. Enter a unique name for the file.
4.3. Click Save PSR File while still in monitoring mode.
The saved .psr file contains both sets of parameters for both 44.1kHz and 48kHz results.
