So bringt man PC Lautsprechern Zivilisation bei
Die Satelliten haben eine Kunststoffmembran.
Der Baß eine Papiermembran.
Sie alle Profitieren von einer Komposit-Struktur.
Ich zitiere hier mal den Erfinder der Sandwich- Membran (oder einen der Bekannteren).
D.A. Barlow: The Development of a Sandwich-Construction Loudspeaker System. Page 159-171. From the AES anthology of articles on loudspeakers, article written 1970.
Citation begin (page 160):
"As paper cones are thin, these resonances are bending modes. The stiffness of a material in bending, for any given geometry and edge condition, is proportional to Young`s modulus and the cube of the thickness, ignoring variations in Poisson`s ratio. ... On this basis, paper is much stiffer than metals (except beryllium) in spite of its much lower modulus, and lower density materials such as expanded plastics are even stiffer, as may be seen in Table. A method of obtaining still greater stiffness is sandwich construction. ... In bending, the maximum stress and strain occur at the outer fibers, the material at the neutral axis being unstressed. Better use of material can thus be made by concentrating it at the outer fibers. A familiar example is the tube. In the case of large areas, the same effect is obtained by using a thin high-modulus material for the outer surfaces, and a light-weight material or form of construction for the core. ... This sandwich will of course be much stiffer than the same total weight of either material used separately. The skin material should have the maximum ratio of modulus/density. Beryllium, the best material, is impractical due to difficulty of rolling and possible toxicity, so aluminium is the obvious choice. The core should be as stiff as possible in the thickness direction and have minimum density. Honeycomb aluminium or impregnated paper are frequently used in aircraft construction and could be used for flat diaphragms."
Citation end.
So bringt man PC Lautsprechern Zivilisation bei - von Freedom666 - 21.12.2010, 09:36 PM
[Kein Betreff] - von Rumgucker - 21.12.2010, 09:46 PM
Membranen - von Freedom666 - 21.12.2010, 09:52 PM
Lernen durch modifizieren - von Freedom666 - 21.12.2010, 10:02 PM
RE: Lernen durch modifizieren - von Rumgucker - 21.12.2010, 10:03 PM
[Kein Betreff] - von E_Tobi - 21.12.2010, 10:14 PM
Schöne Chassis - von Freedom666 - 21.12.2010, 10:19 PM
RE: Schöne Chassis - von E_Tobi - 21.12.2010, 10:25 PM
Impulsschwacher Sound weicher Membranen.... - von Freedom666 - 21.12.2010, 10:32 PM
RE: RE: Lernen durch modifizieren - von alfsch - 22.12.2010, 11:21 AM
