Paper: Interferometrie
Indirekte Energiemessung Der Destruktiven Lichtinterferenz (Indirect Energy Measurement of Destructive Light Interference)
Authors: Wolfgang Sturm
This article is about indirect energy measurement of the destructive light interference.
Comments: 4 Pages. In German
Download: PDF
Submission history
[v1] 2021-08-15 20:02:29
Hidden Energy in the Destructive Interference
Two simple experiments and a simulation show that energy can be hidden in invisible and immeasurable beams.
Comments: 5 Pages.
Download: PDF
Submission history
[v1] 2021-09-27 07:02:01
Hidden Transfer of Energy or Information
In the past, I created a beam of destructive interference and proved that it absorbs energy [1]. The energy of the destructive interference is invisible and cannot be measured by any usual photoelectric, thermoelectric or photoacoustic detector [2]. Surprisingly, a rudimentary parametric oscillator is able to destroy the interference and recover the hidden energy. Thus, it is now possible to hide energy or information, transmit it in an invisible and unmeasurable beam, and extract it at any desired place.
Comments: 3 Pages.
Download: PDF
Submission history
[v1] 2021-11-21 02:40:20
One-Way-Light Speed Measurement
A simple and cheap device is used to check whether the light propagates at the same speed in all directions. It remains to be hoped that the astonishing measurement result is based on a measurement error.
Comments: 4 Pages.
Download: PDF
Submission history
[v1] 2021-12-20 06:54:25
A Message from the Ether
The device developed in [1] enables robust ether analysis. It can actually confirm an ether without any problems. But the ether found has a simpler cause than previously thought.
Comments: 3 Pages.
Download: PDF
Submission history
[v1] 2022-01-12 06:29:28
Seven Theses About Photons and the Perfect Interference
By the experiments published on Vixra in the meantime, seven theses about photons resulted. These theses are listed in a table. Together with the opinion of the mainstream and references to my associated experiments. Attached is another experiment which has not been published yet.
Comments: 4 Pages.
Download: PDF
Submission history
[v1] 2022-02-18 11:33:29
The MM Experiment with Radio Frequencies gives Positive Results
The conversion of the MM experiment (Michelson-Morley) to radio frequencies uncovers a historical construction error, which results in the null result. After its repair, the MM experiment works perfectly even with radio frequencies and achieves a positive and plausible measurement result in the simulation and in reality.
Comments: 8 Pages.
Download: PDF
Submission history
[v1] 2024-07-22 02:30:13
