24.09.2015, 11:34 AM
13 Zellen Batteriemanagementsystem.
E-Bike für Alte?
Zitat:Battery Protection BMS PCB Board w/ Balance for 13 Packs 48V Li-ion Cell max 15A
This item for 1 pieces of Brand new Li-ion Battery Protection Module 48V max.15A with Balance Charging function
Easy Installation
Input voltage DC55-59V
Charing current max.10A
Output current up to 15A
Charging protection and Balance charging
Suitable for 13 packs of Li-ion battery
Dimensions: 68 * 70MM
Applicable: 48V13 series lithium battery protection board
Types of batteries: lithium cobalt oxide / lithium manganese oxide / ternary materials
Single overcharge protection voltage 4.25V ± 0.05V (4.20-4.35V // per 0.05V upgrade)
Single overcharge recovery voltage: 4.10-4.00V
Single Over-discharge protection voltage: 2.50V ± 0.1V (2.50-3.0V // per .05V upgrade)
Single over-discharge recovery voltage: 2.80V ± 0.1V
Protection Current consumption: ?300UA
Short circuit protection current: 40A ± 3A
Short circuit protection time: 500MS
Temperature protection: 55/65 @ 75 degrees
Discharge current; 15A
Single balanced voltage: 4.19V ± 0.02V
Single balanced current: ? 55MA
Zitat:Single balanced voltage: 4.19V ± 0.02V
![[Bild: 179_Papst.jpg]](https://stromrichter.org/d-amp/images/forumuploadpics/179_Papst.jpg)
![[Bild: 99_Chef.jpg]](https://stromrichter.org/d-amp/images/forumuploadpics/99_Chef.jpg)
. Musst du den eigentlich jedesmal aufmachen, um zu laden? Oder hängt das 1000-Kabel-Interface einfach so raus?Zitat:
![[Bild: 113_Step+Down+2.jpg]](https://stromrichter.org/d-amp/images/forumuploadpics/113_Step+Down+2.jpg)
Elektromotor.
Wozu braucht ein Elektromotor eigentlich Energie?
Die Spule braucht ja nur Strom, keinen Widerstand und schon gar keine Wärme.
Lampe: CREE XML-T6 - 3Stufen ca. 10Watt
+ der Converter
= sollte ich ausser dem Schalter eine Sicherung vor den Wandler machen ?
Type:
