13.01.2006, 03:25 PM
Okay, I killed another pair of output MOSFETs today by accidently shorting the output. They get killed faster than the 6.3A fuses I have in the power supply, hence I need a good shortcircuit protection. I've been looking at current sensing with a LM393 comparator that monitors a 0.05-ohm resistor in the power supply lines leading up to the amplifier. Anybody got a working schematic?
Best regards,
Sander.
Best regards,
Sander.
